Originally posted by Mike1832 View Post
I just tried this. Windows 7 did find a USB device and wanted install drivers. But this failed. Now I'm not able to reproduce this.
Originally posted by DS-1 View Post
You should install the Rockchip drivers first: https://androidmtk.com/download-rock...iver-assistant
You should shorts these two pins (7 and 8) while you put the USB cable in the PC with the red circle.
After a second, a tool like AndroidTool should recognize your board in MASKROM mode.
Finally I'm able to connect to the pc with the RK Android Tool 2.3.9. This brings up FOUND ONE MASKROM DEVICE. Another Tool says TEST DEVICE FAIL. So I can't install another firmware. Must I first install the boot bin? If so, where to find the .bin file? Or I'm completely wrong?
Originally posted by gidabytes View Post
May be it's helpful for someone.
Originally posted by pro777 View Post
Originally posted by dionisor View Post
Seems to be the same for GT1 Ultimate (SN A706D0), It's true?
Founded another pins (picture 3) but I'm not sure.
Could anyone help me. Thanks!!!
Instructions:
1. Install Usb Burning Tool 2.0.9
2. Load GT1_706D0_AP6255 FW file
3. Check:
Erase Flash -> Normal erase
Erase bootloader
4. Press Start
5. Short pins and wait until device discovered and program start.
Good Luck!!!!
Solved!!!!!
Instructions:
3. Check:
Erase bootloader
4. Press Start
Good Luck!!!!
Solved!!!!!
Instructions:
3. Check:
Erase bootloader
4. Press Start
Good Luck!!!!
There are currently 2968 users online. 1 members and 2967 guests.
