Hi Hotrod1, I have a totally bricked Q5x3_141 V4.1 device, it does not turn on any lights and the USB is not detected... I have tried your suggestion and still not "waking up", you have been able to unbrick your device? How? Any guidance you can give me will be welcome.
Thanks, Bernardo.
Originally posted by Hotrod1 View PostThe picture in comment #822 shows the wrong pins. These are the correct pins confirmed.
Originally posted by bertdf View PostHi Hotrod1, I have a totally bricked Q5x3_141 V4.1 device, it does not turn on any lights and the USB is not detected... I have tried your suggestion and still not "waking up", you have been able to unbrick your device? How? Any guidance you can give me will be welcome.
Thanks, Bernardo.
Hi Hotrod1, thanks for answer. Here you have them... it is a generic brand -Profiber 4/32Gb- but it is observed that the board is X96, I assume it will be similar to X96 MAX Plus Q2 4/32Gb or X96 MAX Plus 4/32GB.
Any help will be welcome, I have tried everything without success.
front (https://ibb.co/LSL0j87)
back (https://ibb.co/T131LsF)
Thanks, Bernardo.
Post a good quality pic of each side of your board and the complete model name and all the hardware specs and I'll see if I can help you out.
Hi guys.
Have X96 Max 3, had Slimbox ROM, rooted, and TWRP installed.
Wanted to go back to stock because didn't manage to get Netfilx in FHD.
First I installed official recovery, then, official ROM X96Max_Plus2_20200901-1005 ROM
That went without any errors, but after reboot, it stucked there.
Tried to short pin it, nothing. (already done this few times before, every time worked, till now)
But, if I leave it connected via USB A-A cable to my computer, after 10 mins it boots, but UBT won't recognize it.
Tried few versions of UBT, but no luck.
Pics are here:
You must touch something metallic across the 2 pins in the red circle in this pic. Then connect the usb to the box. Watch this video he shows you how to unbrick using Mask ROM. You must load the ROM in the Amlogic burner before you connect the usb.
x96 max plus: short nAND to SD ground: https://uploads.tapatalk-cdn.com/202...d1121a49b9.jpg
Try any pins on BGA chip backside and try to short to SD card's housing ground
Originally posted by bertdf View PostHi Hotrod1, thanks for answer. Here you have them... it is a generic brand -Profiber 4/32Gb- but it is observed that the board is X96, I assume it will be similar to X96 MAX Plus Q2 4/32Gb or X96 MAX Plus 4/32GB.
Thanks, Bernardo.
Hi Hotrod1, I was finally able to "revive" the box, I leave below the step by step that has worked for me (Option 2).
Option 1 (for most cases)
- Get the box without power or USB connection
- Open the software Amlogic USB burning tool
- Select the image to burn
- Connect your male to male USB cable to the PC
- Put something metallic (a screwdriver) between the pins which are in the orange circle of this image and hold -verify that the board is the same than the picture
- Connect your male to male USB cable to the box to USB 1 port
- When you hear the sound on the PC that has detected the box, remove the screwdriver
- Plug the box into electrical power
- Click on the ‘Start’ button to proceed with the burn
Option 2 (when Option 1 it doesn't work)
- Plug the box into electrical power and wait for about 5 seconds
- Disconnect the box for the electrical power
- Follow the steps in Option 1
The only ROM that I found where everything works (bluetooth, wifi, etc) is this Slimboxtv X96 Max Plus Q1
Thanks, Bernardo.
There are currently 2234 users online. 1 members and 2233 guests.
