Guest
Guest
Method #1 (bricked)
Start usb tool with rom loaded, plug in USB
touch between pin 5 and 6 on this side as shown in arrow.
Method #2 (if hard bricked)
Start usb tool with rom loaded, short 5 and 6 with needle and keep in on pins, while plugging in the USB
it will start to flash.
Cheers
1 Photo
Guest
Need better pics closeup. And chances are that chipset is really old... it might not be worth doing anything with it. It depends... the board is dated 2014 .... s8xx s9xx series.... super slow.
get me somemore info.... cheers
Originally posted by Kyle222 View PostNeed better pics closeup. And chances are that chipset is really old... it might not be worth doing anything with it. It depends... the board is dated 2014 .... s8xx s9xx series.... super slow.
Guest
don't even bother with that box... you can buy one cheap online for $20 or less with s905x or better processor 1g/8g
the processor on that board is worthless AML8726
Guest
Good point, it does have a tuner so you are limited to which ROM you can run on it. I believe the original ROM was 4.2.2 on that box. As you need all the firmware modules for channel selection and scanning.
And it's only a dual core 1.2 thru 1.5g
Cheers
Hi need help shorting this.
X96Q 4+64 H313
Using KLM8G1WEMB-B031 eMMC.
Tried my best on trying to find it. Even scratched off some off the board to try short.
http://www.datasheetcafe.com/klm8g1wemb-b031-datasheet-emmc-nand-flash-memory/You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
There are currently 3159 users online. 1 members and 3158 guests.
