    I take 2 pictures of front and back of my mibox 2s
    Could you say me which one is CPU ?
    And how can I get it to Mask mode??
    Sent from my Nexus 5 using Tapatalk
      Hi ,
      you have a AML CPU , not sure if it is called the same , MaskRomMode is used for
      Rockchip Devices , it is only a Name , you can get into it , if you short special Pins
      on your Nandchip , this only must be done if your Box is bricked and you can not
      connect it the stock Way , Download Mode is the stock Way for AML Boxes , i think ,
      if it is possible to connect your Box the stock Way , try this first , no need to use the
      restore Modus of PCB , remember , you must have the correct Rom to flash ,
      good luck / gefattern
      I got it , I got it finally
      thank you
      This mode for amlogic devices is "World cup" mode
      And my device is in that mode
      Problem is official ROM
      Our flasher just feed .IMG ROM but my device official ROM is with .zip
      I can convert it to .IMG but at the end I need partition table .
      That's it , I don't have partition table
        Originally posted by soldiaz View Post
        thelinhlge ...does not work :-(...
        It work for me with my. X1 nand chip
          thank you
          Hi ,
          yes that is correct , you need a .img File , but what happens if you unzip it ,
          no convert , look for a unzip App or Tool and unzip that File and report what
          is inside , good luck / gefattern
            Hi ,
            When I unzip the Official file there is these files :
            We Extract these files into the flash memory and boot to download mode to update the device (In normal mode . Before bricking)
            And what is in "update.zip"?
            Thank you
              Click image for larger version  Name:	1.PNG Views:	1 Size:	37.1 KB ID:	764413
              Click image for larger version  Name:	2.PNG Views:	1 Size:	61.7 KB ID:	764414
              Thank you
              Hi ,
              there are three Ways to flash , with PC and SDCard & Recovery , your .zip is the Recovery or SDWay , i think ,
              more Recovery , but if you want to flash with PC , you need the full .img File for your Box , i cant say if the
              SDWay or Recovery Way shall work on your Box , please use the "search" to find more over MiBox , until
              now we have no own Category for this Players , maybe better to look for a MIBox Forum , but sure you will
              get it solved , YouTube is helpful too , looks like you have both Files one .zip & one .img is this correct ???
              what size has the .img file , good luck / gefattern
                thelinhlge : is it a picture of your board? I painted the soldering points. Could you kindly indicate which colored dots you shortened? Maybe I shorted wrong...from left side: yellow, orange, rose, lightblue
                  Pls trying short the Yellow and Orange.
                    Hi ,
                    I don't have .IMG file , I downloaded Minix m8 official firmware and unpacked it
                    i replaced base files and repacked it
                    But couldn't flash it
                    Flasher said : partition table error
                      Hi ,
                      it looked on the Pictures like it , but you can for sure download the latest Rom for your Box somewhere
                      online , maybe the best to look here for update.zip Instructions :
                      https://en.miui.com/thread-2997042-1-1.html
                      https://forum.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s905x/577844-original-xiaomi-mi-3-tv-box-amlogic-s905x-quad-core-update/page3
                      it if for MI 3 but you can ask for flashing Guide ,
                        I have this version of box
                        cant find what pins to short anywhere
                        help please
                          help
                            I think the chip within the yellow container is supposed to be shortened. I would try by gently shorten pin after pin on left side (marked lightgreen). If unsucessful then try right side (marked lightgreen)...
                              i tried nothing happens
                                I recommend THIS to get into MASKROM mode.
                                Turn on whatever version of the tool you are using to flash your new rom. Then plug your device into your computer. Make sure you have drivers installed.
                                Walk down every pins you think may be the ones. With a little patience, you should find the right one.
