Where should I short?
Mecool BB2 PRO Amlogic
Samsung 640 KLMAG2WEPD-B031
UP: I find out the pins. PINS 17-18 left side.You may only view thumbnails in this gallery. This gallery has 3 photos.3 PhotosLast edited by Powarock72; 16 August 2019, 17:13.
Hello,
I have successfully un-bricked my TV box. Here are the steps with High Resolution pictures and NAND Chip Mask ROM Mode Short Location
My TV BOX: T95D Android TV Box Rockchip RK3229 Quad Core BT4.0 RAM 2GB DDR3 ROM 8GB 2.4GHz
High Resolution Pictures:
https://ibb.co/XC43jWk (inside the case)
https://ibb.co/YRCQd56 (front)
https://ibb.co/72G2GpY (Back)
Short either pin 13-14 or pin 14-15. The chip is very small thus I cannot be sure.
https://ibb.co/dbrHsvM (Nand pin short location)
NAND Chip Name:
SAMSUNG 634
KLM8G1WEPD-BO31
Flash tool used: AndroidTool_Release_v2.43
Rom Used:
http://tvdestek.com/Konu-sineplus-8-...ware-wifi-8703
Rom Location: http://sineplus.tv/sineplus/LeelboxR...-kodi-1225.rar
Steps:
- Start AndroidTool_Release_v2.43
- Load the Rom
- connect USB Male-Male cable with computer and TV box
- connect 5v power to the TV Box
- Short the pin
- AndroidTool will recognize the box. You now can remove the pin shorting screwdriver or anything else you are using.
- Press Upgrade and it will flash this ROM to this box.
- Once flashing is complete the box will reboot itself.
- Close AndroidTool and enjoy your un-bricked box.
I hope I did not miss anything here.
Regards
I have tried everything with my a95x pro but with no succses. BurningTool and windows are not recognizing my device. I have tried to short those two pins also no succses, holding AV reset button pluging USB and adapter. I give up.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Box: MXQ pro 4k
Model: MXQ-4K-3229XD2-20161117-V0-2
1GB RAM
8GB Storage
I tried shorting all the visible points on board before, but it didn't work.
Then i thought it must be because i was using a USB hub, so i plugged the USB cable directly on my pc's back USB port and it worked right on first try ^^
Hi All,
I am trying to work out where to short the NAND on a board of a friend of mine.
I searched all the way over the internet but was not able to find it, untill I came accross this thread, which seemed hopeful but sadly I can also not find it here so far.
Maybe this will change it.
The board is exactly the same as these 2 posts but I cannot seem to find anyone who found it for this specific board.
Can someone help me please?
See posts:
https://forum.freaktab.com/forum/mai...494#post733494
https://forum.freaktab.com/forum/mai...943#post733943
Thanks in advance for your time!
Originally posted by robbo1829 View PostHi the correct pins are just right of the ones you have marked. just shorten all on the right and your device will be recognized. I have done this and it works the Rockchip batch tool loaded my device.
Tried all pins from the picture you marked but no success.
Can you tell me right order to do it, do I need power adapter also, do I need to press Recovery button, what pins exactly need to short.
Thanks.
There are currently 3755 users online. 0 members and 3755 guests.
