Hi friends i bought hk1 mini plus rk 3318 about one month ago when updating electricity gone then it stuck on red light not opening searched on this forum and i figure out it was bricked i tried on batchmode and android tool , factory tool it showing blue mode (maskmode ready) every program i tried showing error idb failed i will try short circuit method please anybody can show me pin points.
Guest
Originally posted by Nebojsa View PostYes I tried that way, connect power, (press andhold reset button), short pins and insert USB plug, but nothing.
2. Connect power adapter to the box.
3. Short pins and you should have connection...
Tried lot's of variants but without luck.
connect to pc, connect power, shorting pins
connect power, shorting pins, connect to pc
shorting pins, connect to pc without power
press recovery, connect to pc
press recovery, connect power, connect to pc
press recovery, connect power, shorting pins, connect to pc
Maybe I'm using wrong pins.
PC, cable and drivers are ok, tried to connect other working box and it's recognized without problems.
Originally posted by CaptainBenSisko View Post
You're already in MASKROM mode. What did you do to get to this point?
I'm looking for this chip's pin short (Nexbox A95X (S905) ) . Thx!
I found three shorts on the NAND, 1-2; 12-13; 35-36, but none of these helped to upload rom. USB Burning Tool's stops : 1% Download DDR
Code:[12:55:57 919][HUB1-2][Inf]--Start burning... [12:55:57 970][HUB1-2][Inf]--------------ERASE BOOTLOADER------------ [12:55:57 970][HUB1-2][Inf]--2-0-0-0 [12:55:57 970][HUB1-2][Inf]-------------Download DDR.USB----------- [12:55:57 971][HUB1-2][Inf]--2-0-0-0 [12:55:57 971][HUB1-2][Inf]--Control write pll reg1 0xd9000000:0x000000b1 [12:55:58 471][HUB1-2][Inf]--Control write pll reg1 0xd9000000:0x00005183 [12:55:58 972][HUB1-2][Inf]--Write initial succeed [12:55:58 972][HUB1-2][Inf]--Upload encrypt at 0xc8100228 [12:55:58 972][HUB1-2][Inf]--ulValue = 0xedfc318c [12:55:58 972][HUB1-2][Inf]--Read encrypt value succeed [12:56:09 501][HUB1-2][Err]--Download file failed, sequence 0 [12:56:09 501][HUB1-2][Err]--usbWriteFile len=4096, ret=-116 error_msg=libusb0-dll:err [_usb_reap_async] timeout error
Code:GXBB:BL1:08dafd:0a8993;FEAT:EDFC318C;POC:3;RCY:0; EMMC:0;READ:0;CHK:F3;SD:0;READ:0;CHK:F3;USB:8; LOOP:1;EMMC:0;READ:0;CHK:F3;SD:0;READ:0;CHK:F3;USB:8; LOOP:2;EMMC:0;READ:0;CHK:F3;SD:0;READ:0;CHK:F3;USB:8; LOOP:3;...... ... ...
i have two devices the same model HM8 golden one, are not working anymore, just red lamp not even booting, not responding to anything, can't enter to recovery mood to rest it. 1- when i connect it via usb with laptop to flash the firmware by USB_Burning_Tool it stops @7 %, I tried all possible installations steps. between
another picture for HM8, hope it\s more clear, Its red lamp, only by using sd it is working but never accept any firmware. and the green lamp appear
any idea how shorting NAND can solve the issue? and which pins
حجم الخط
There are currently 3453 users online. 0 members and 3453 guests.
