Hello
I got a a95x f3 Air that doesn't boot (only red light), I already tried to flash it using amlogic burning tool,the computer recognises the box,but it gives errors when flashing and stops exactly at 7% formatting, I tried different firmwares besides the original firmware from the supplier himself, always the same error, I tried the sd card method but still nothing the box doesn't even turn on, (there's just a red diode that turns on).
First I used to get this error
0x32030201]Uboot/Get result/DiskInitial error
But lately I've been having this one
0x10303004]Romcode/Switch status/Identify/ Error result
I'd like to mention that the problem started when I forced shutdown the box by unplugging the power, because it just froze and didn't respond anymore.
Can someone please help me to find the short pin of the x92 android box s912 3gb ddr3 32gb
20200401_141224.jpgHi All, I flashed wrong Tanix T9 Pro rom (TX9pro-20180205.img) which I downloaded from Tanix site. Initially flashing was failing at 2% receiving the error "[0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error" .Then I read somewhere that uncheck the "Erase
You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
I did something stupid today by installing VIM1 ATV 9 on my X96 S905x box. it works but keeps rebooting ever so often. Now, normally i would just use usb burning tool but, it seems there is no recovery on the box and usb burning tool is not detecting the box. i have tried to short the pins but still no luck. i have tried the 1st and the 2nd pin which restart the box. and also pin 5 and 6 which does nothing. Can someone please advise or do i need to throw the box in the bin?
Hello eveyone,
I have H96 Max X2 S905x2 Amlogic tv box. Anyone know to where is the pins on this tv box?
pls help me Usb tool dont see my device after flash to SuperCeleronMulti custom rom. Maybe I can fix with the way.
Thank you allYou may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Thank you allYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
There are currently 2270 users online. 1 members and 2269 guests.
