Help to bring MXQ Pro 4K back to life
Thank you for allowing me joing that great forum.
I really need your help to make my MXQ pro 4K comes back to live . Story started when the box was stoped working and didn't boot or even had its Led on . So I plug it into my lap top tring to use hrad reset by toothpick , OTG usb port and downloading the firmware for AMlogic (thinking thats the correct chipset for that type of boxes as shown on interent). But the burning tool couldn't see the box . So I guess the box has different chipset and my guess was right so I used the tool for Rockchip and downloaded two frimwares for trial. the first firmware was upgraded but the wifi wasn't working then when I try the second firmware the box totaly diedno Led no detection on Rockchip tool. At the end I decided to open the box then was the surprice I found that the chipset is Toshiba I tried to short the pins but no luck . Please see attached photos for the mainboard so grateful if someone can help me to bring that box back to life.
Originally posted by giornistrani View PostHi guys, a friend suggested me this site to solve my problem. I have a Mediacom 875 s2 tablet and I should test point. Can you tell me the right pins and what should I do? these are the photos of the motherboard. Thanks
try shortening any of these WHILE connecting to PC!!
Any advise on which pins on that PCB with toshoba chipdset for Maskrom Mode? I have tried all of the chipset pins but not come up
Originally posted by mAtvXk View Post
There are currently 1441 users online. 1 members and 1440 guests.
