[ROM] Mecool M8S Pro Stock & Nano Nexus ROMs (Android 7.1)
Guest
Originally posted by thgiakit View Post.....Unfortunately, I had no luck. I am afraid your box is dead my friend
post #3300 on 4PDA.ru
Originally posted by mAtvXk View Post
Maybe not, let him try with mask rom method, flashing the original firmware back by shortening the pins on NAND flash !?
Box has to be plugged in power for that to work or I just disassemble it and short those pins without plugging anything?
Guest
Originally posted by Tyrannar View PostBox has to be ...
1. Remove the cover of the attachment.
2. Download and install the Amlogic USB Burning Tool, launch the program, select the firmware via Import Image (M8S_PRO-NMF26Q-20171030.162112.V0619.img).
3. We decide on the contacts that should be closed (The third pair of contacts). (It is better to rehearse the entire firmware procedure several times).
4. We close the contacts and connect the PC to the set-top box. If all goes well, a beep sounds and Connected appears.
5. Connect the power supply and press the Start button.
6. After the end of the firmware, click Stop and close the program." [translation]
There are currently 41510 users online. 1 members and 41509 guests.
