[ROM] Mecool M8S Pro Stock & Nano Nexus ROMs (Android 7.1)
I need to make sure I am right before I proceed. I loaded one of the earlier versions of this last October and currently am on 7.1.2 NHG47L 20170918.111557.V0619 (stock build) Can I just upgrade by loading the OTA for Stock and nothing else? I just want to be sure before proceeding. Thanks in advance.
Originally posted by BigDaddy View Post
Same issue here. In power settings I set box to turn off completely, next reboot wifi comes on as normal or you have to go to wifi connection and disable wifi and back on manualy. This issue was not there on previous release.
Kodi 64 Bit, is there a way to have this work on this box? I assume the build.prop may need to be adjusted so the box is recognized as something other than a phone. The install error states it's not compatible with your phone.
UPDATE: I believe I figured out why. Even though the CPU is 64bit the OS is probably 32bit....... damn =)Last edited by Prez; 14 May 2018, 14:19.
Originally posted by Prez View PostKodi 64 Bit, is there a way to have this work on this box? I assume the build.prop may need to be adjusted so the box is recognized as something other than a phone. The install error states it's not compatible with your phone.
Originally posted by Phana View PostSorry I have installed the ROM successfully, but how can I root this device ?
Sent from my GEM-703L using Tapatalk
Okay... Stupid questions that need answers:
I preface them with a big thank you for saving me from an impending aneurysm.
1) How to ditch, or hide Google now screen wide search bar?
... I'm able to do this on most custom phones ROMs, what am I missing?
2) How do I reliably, consistently mirror or cast lg g3 content (primarily YT red downloads)
... WITH ONLY The benefit of "hotspotting" or bt paring.
Presently NO 3rd party wifi network to pair both devices to.
Surely this is possible, with the proper apk helping Yes?
I am stuck and frustrated as hell!
Please, advise and opinions to clarify what is needed
Many advance thanks ! - CK
Guest
Changelog (20180829):- Updated to latest M8S Pro OEM firmware (20180412.194117.V0213)
- Updated to TWRP Recovery 3.2.3-0
- Preserves Miracast from OEM firmware
- Latest build from Open GApps (20180828)
- Clicking on Vision Settings in the setup wizard will launch an unsupported activity in Settings.
- You can enable the nav bar in Settings->Display->Statusbar, but may need to toggle back and forth before it will show.
- Nano Variant: BURN PACKAGE (930MB IMG file), OTA UPDATE (479MB ZIP file)
- Stock Variant: BURN PACKAGE (1.46GB IMG file), OTA UPDATE (824MB ZIP file)
Guest widevine 1 and drm, etc. Working as on prior rom?
... Which was based on "L" oem?
Correct?
Thanks for remembering us po 'PRO' peeps!Kris....don't forget my boxes! Okay?
No, this is from the actual M8S PRO OEM firmware posted 6 days ago: http://blog.geekbuying.com/2018/08/m...date-20180412/
It should work if you have L1 on your M8S Pro, but I never got my "fix" and so I can't test it.
Originally posted by Magendanz View PostChangelog (20180829):- Updated to latest M8S Pro OEM firmware (20180412.194117.V0213)
What about TVStock? Abandoned forever?
There are currently 1962 users online. 1 members and 1961 guests.
