Thank you
[ROM] Mecool M8S Pro Stock & Nano Nexus ROMs (Android 7.1)
Guest
Changelog (20171116):- Updated to latest M8S Pro L OEM firmware (20171109.180937.V0928)
- Added additional option (Reboot & Sleep) to global action menu that displays when you press and hold the Power button.
- Latest build from Open GApps (20171116)
- Nano Variant: BURN PACKAGE (910MB IMG file), OTA UPDATE (466MB ZIP file)
- Stock Variant: BURN PACKAGE (1.38GB IMG file), OTA UPDATE (781MB ZIP file)
Mag, would you advise me how to enable 1080p in Netflix with your V619 Nano? I have premium subscription and I did side-load the last netflix.apk , but it seems I am limited to 512p....
Hi Magedanz! I successfully migrated to your latest Stock Variant OTA update. Could you please advise me how can I update any future OTA firmware, since there are no Update app anymore. Thanks and best regards.
Thank you for your prompt response, Magendanz. Does it mean that we can have real OTA support and where will be hosted the updates. I have installed as well the Official TWRP App and in case future OTA release in zip format, I need just to go -> TWRP Flash -> Select a file to flash.. ? Do I need to make again data wipe, together with the update. If I want to test future OTA update from Mecool, to assume using the same method with TWRP app. Apologies for my lack of knowledge in the field. Thanks
Well, all of my custom ROM updates will include the latest TWRP for that device, which I build myself using the latest device kernel from stock recovery. Generally, you'll only need a data wipe for major upgrades, such as changing Android versions or variants (Android TV vs. non-ATV). The nice thing is that you can first try it without, then if things seem fishy just do the factory reset later from Settings.
Also, the new updated app includes a Backup and Restore feature, in case you need to do a data wipe.
Tried it- nothing happens.. I just hitted OFF several times but there is still status bar at the top (clock, connected devices etc) and still the grey line at the bottom in Netflix.
May be I should change to your TVStock Rom?
EDIT:
OK, got it. It was OFF actually, so that wasn't the problem...
May be I really have to flash your TVStock version...
Yes, it's really named incorrectly. The "Statusbar" setting doesn't control the status bar, but the navigation bar at the bottom. And as I point out in the release notes, it's a bit flaky.
If Netflix playback is your main usage, then the TVStock variant will probably be more to your liking and generally tends to work more seamlessly with Netflix when downloaded directly from the Google Play Store. Not everyone is an Android TV fan, though.
Thanks so much for your help!
So you are saying if I use my box mainly for Kodi and Netflix - TVStock is my best bet?
Yes, that's what I'm saying. Google designed Android TV to be used from a distance with a remote control (what we call the 10-foot UI), and for the most part I think they succeeded. It's not perfect, but it is a hell of a lot more polished than what most Chinese OEMs are shipping as their default launchers.
The non-ATV variants (Nano & Stock) are really more designed for use with a mouse and keyboard.
I'm a little bit confused about how root is setup / enabled on these roms?
Usually if a rom is rooted you have something like SuperSU installed???
A second bug i discovered in nano rom ( 1st is , you cannnot install live wallpares), is that you cannot use the "teamviewer app" . To be more specific, you can control your mobile from the box but you cannot control the box with your phone/tablet.
There are currently 3107 users online. 2 members and 3105 guests.
