[ROM] Mecool M8S Pro Stock & Nano Nexus ROMs (Android 7.1)
Originally posted by Magendanz View Post
Build prop: DPI settings. Three digit number, approximately around 210.
edit and raise by twenty points. See how that looks to you.Kris....don't forget my boxes! Okay?
#108.1Guest commented27 October 2017, 06:57Editing a commentI recommend you use one of these standard Android density values, as they're going to have better test coverage and performance optimizations: https://developer.android.com/refere...ayMetrics.html
Originally posted by ClarkKent View PostBuild prop: DPI settings. Three digit number, approximately around 210.
Greetings all,
I have been attempting to install the file 'update_M8S_PRO-V0619_Stock-20171005' onto my M8S Pro using the Updater on the system (and installing from a USB stick). When I attempt to do so I get an error which reads something along the lines of 'This update is intended only for the M8S Pro'.
The machine I have is based around the Amlogic q20x board (according to DRM Info) and (supposedly) contains the Amlogic S912 rather than the S905 which rules out it being an M8S Pro +. Also the casing does not display an L which would indicate that it is the newer L model. However, widevine/security level in DRM Info is L1. I have read that some M8S Pro's have L1 rather than L3.
I'm curious as to why the update finds that this machine is not a Pro, could it be an L in a different case and could this be why the install did not work?
Any assistance would be greatly appreciated.
Edit: Attempted to install the earlier 'M8S_PRO-ota-20170707.094011.V0321-fixed' which appears to install fine but then hangs partway through a fancy Mecool intro sequence. It then reboots and reinstalls the original Mecool firmware.Last edited by DrBlue; 28 October 2017, 00:22.
Greetings,
Does anyone know, if there is alternative Shiningworth firmware for M8SPRO available? Maybe it would be more stable, than VS firmwares..
There are currently 2677 users online. 1 members and 2676 guests.
