[ROM] Mecool M8S Pro Stock & Nano Nexus ROMs (Android 7.1)
Originally posted by aspittles View Post
#61.1Guest commented04 September 2017, 21:34Editing a commentFor an SD card install, you'll need Amlogic's BootcardMaker, which is also linked from the original post. I don't think it works with a USB flash drive, though.
Personally, I find the USB Burning Tool much more reliable, if you can find a male-to-male Type A USB cable.
hello friend magendanz ha, first of all I want to congratulate you for your rom, I apologize to you because I do not speak English and I have to translate this conversation, I am writing this message to request your help since I am new to the subject of installing rom in tv box, buy a tv box ms8 pro of 3gb of ran and 32gb rom in aliexpress I worked well for a few weeks, but after a while it started to get frozen in the beginning in the image of mecool, so I decided look for solution to the problem and in the forum of the page androidpc, I was suggested to install another rom so I get to this page and your tutorial, installing by means of sd card the rom nano20170825 that you publish in # 39, after installing it erase the data through TWRP Recovery,
I restore it from the factory, then install some applications and there are problems started: - because it started to freeze the window moved the mouse cursor but could not execute anything from the window -I connected to Bluetooth through my cell to send an apk that wanted to install and the box box recognized me but did not receive the apk salian that were not supported - finally turn it off when I freeze the android and when it was frozen it was frozen in the beginning or in the image of nexu in that you can help me to work well my tv box with this rom, or that I did wrong, I hope your answer and in advance many thanks
Ok, thanks friend a question when you plan to launch the rom based on Tanix TX8 Max and you talk in # 48.1 how's that going?
Originally posted by jzf23 View Postwhen you plan to launch the rom based on Tanix TX8 Max and you talk in # 48.1 how's that going?
Everything is alright in TV ROM. But when I try to flash last nano ROM, I got error 7. What am I doing wrong?You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
You seem to have wiped the previous system partition, so it's got no build.prop to check its environment. You'll need to use the burn package (.img file) and Amlogic USB Burning Tool now.Last edited by Guest; 09 September 2017, 21:42.
Hi there, and thank you Magendanz for these ROMs.
I have received my m8s recently and installed the last Stock Variant directly. But I never managed to connect to any bluetooth "remote control" app despite trying a dozen... The tv box is quite unpracticable without a keyboard.
I didn't try on the OEM ROM. I don't have any physical bluetooth keyboard to try either.
Does anybody experience the same issue? Any hints? Any working android app? Can it be linked to the Rom?
good morning megendadnz, apologies but I have a concern that I would like me to solve it and beforehand pardon the hassle, the rom of this tv box I can install in my ms8 pro of 3 gb of ram and 32 gb of rom, https: //androidpc.es/blog/2017/09/12/firmware-mecool-kiii-pro-s912-3gb-con-sintonizadores-dvb-s2-y-t205-09-2017/ Thank you for your cooperation.
my question or concern is if I can install the firmware of this address (https: //androidpc.es/blog/2017/09/12/firmware-mecool-kiii-pro-s912-3gb-con-sintonizadores-dvb-s2- and-t205-09-2017 /), on my tv box ms8 pro 3gb of ram and 32gb of rom, ok and beforehand thank you very much
Probably not. The M8S Pro .img files are very particular about which devices they'll support. You'll have better luck with the new Shiningworth generic S912 firmware that I used as the foundation for these GT1 custom ROMs: http://freaktab.com/forum/tv-player-...ms-android-7-1
I tried the TV Stock New Rom which I downloaded on 08/27 and could never get Google setup because of wifi dropping issues and couldn't get any further than that. Then I tried the Stock firmware and was able to do everything I wanted. Has anything changed since that date to fix the wifi issue on TV Stock? I would like to try it again if it has changed. Thanks for the work you have done on this. I like this load very much.
I ordered the Mecool M8S PRO Amlogic S912 3GB DDR4 RAM 32GB.
What do you suggest to do when i receive it? Stay on stock rom or flash another? Are there a lot of bugs in stock rom? In my mind is nano "all in one" cause Magendaz said good words for them and i dont need ethernet to be worked. On the other hand i need bluetooth to connect BT joystick. I hope there is no bluetooth problem with nano AIO rom.
Thank you
There are currently 2593 users online. 1 members and 2592 guests.
