[ROM] Mecool M8S Pro Stock & Nano Nexus ROMs (Android 7.1)
    In the spirit of the Pure Nexus Project, these Nano and Stock Nexus ROMs prove that less can be more. The goal is to keep true to Google's vision and use the bare minimum of OEM or third-party apps or add-ons, which can be added à la carte by the user as needed. These ROMs also serve as a foundation for TVStock Nexus ROMs, which deliver the pure Android TV experience using the Open GApps TVStock Package.
    Stock Nexus variant includes:Nano Nexus variant includes:
    • Open GApps Nano Package
    • Google Now Launcher (replaces OEM Launcher)
    • Google Chrome Browser (replaces AOSP Browser)
    • Google Legacy Camera (replaces AOSP Camera)
    • Google Desk Clock (replaces AOSP Desk Clock)
    • Google WebView (replaces AOSP WebView)
    • Terminal app from LineageOS
    • TWRP Recovery 3.2.3-0 by TeamWin
    Changelog (20180829):
    • Updated to latest M8S Pro OEM firmware (20180412.194117.V0213)
    • Updated to TWRP Recovery 3.2.3-0
    • Preserves Miracast from OEM firmware
    • Latest build from Open GApps (20180828)
    Changelog (20180310):
    • Updated to latest M8S Pro L OEM firmware (20180205.111652.V0928)
    • Wake from sleep is now working, and taking the expected 2-3 seconds.
    • New build of Mali driver that supports OpenGL 3.2 + AEP
    • Latest build from Open GApps (20180310)
    Changelog (20171116):
    • Updated to latest M8S Pro L OEM firmware (20171109.180937.V0928)
    • Added additional option (Reboot & Sleep) to global action menu that displays when you press and hold the Power button.
    • Latest build from Open GApps (20171116)
    Changelog (20171103):
    • Updated to latest M8S Pro OEM firmware (20171030.162112.V0619)
    • Removed attempt to launch voice assist on Back button long press. (Only valid for watches)
    • Latest build from Open GApps (20171103)
    Changelog (20171005):
    • Updated to latest M8S Pro L OEM firmware (20170918.111557.V0619)
    • Underlying OEM firmware updated to Android TV 7.1.2r11 (NHG47L)
    • Added support for all HID devices (e.g. remotes, gamepads, etc.) on latest Nougat firmware for Nexus Player, NVIDIA Shield TV & Xiamoi Mi Box
    • The Terminal app now shows only when enabled in Developer Options
    • Restored default settings (e.g. animation scale, sound effects) from Nexus Player
    • Latest build from Open GApps (20171005)
    Changelog (20170825):
    • Updated to latest M8S Pro OEM firmware (20170801.150811.V0321)
    • Underlying OEM firmware is now pre-rooted, and so ours is too
    • Latest build from Open GApps (20170825)
    Changelog (20170807):
    • Replaced Jack Palevich's Terminal Emulator with Terminal app from LineageOS, tweaking manifest so that it always shows in launcher
    • Included additional keyboard layouts
    • Included OTA updates as well as the full Amlogic burn packages
    • Latest build from Open GApps (20170807)
    Changelog (20170721):
    • Mecool M8S Pro V0321 OEM build stripped to Android stock bits and Open GApps
    • Nexus splash logo with stock Android boot animation
    Known Bugs:
    • Clicking on Vision Settings in the setup wizard will launch an unsupported activity in Settings.
    • You can enable the nav bar in Settings->Display->Statusbar, but may need to toggle back and forth before it will show.
    Download:Notes:
    • The underlying OEM firmware for this build is pre-rooted, so this is too.
    • The updater is signed, and so can be installed in the Update app, the stock recovery, or TWRP. It's designed for incremental updates, since user data is preserved. If you're installing for the first time, you should include a data wipe.
    • The safest bet is always to install the full Amlogic burn package with USB Burning Tool.
    • Flash ROMs at your own risk and always remember to back up your data first. The burn package includes a factory reset.
    Credits:Donations:
    • Your support is always appreciated! Just click here.
    Click image for larger version  Name:	Screenshot_20170721-072938.jpg Views:	2 Size:	9.9 KB ID:	657567Click image for larger version  Name:	Screenshot_20170721-072953.jpg Views:	2 Size:	16.5 KB ID:	657568Click image for larger version  Name:	Screenshot_20170721-003105.jpg Views:	1 Size:	14.7 KB ID:	657556Click image for larger version  Name:	Screenshot_20170721-003120.jpg Views:	1 Size:	35.5 KB ID:	657557Click image for larger version  Name:	Screenshot_20170721-003203.jpg Views:	1 Size:	24.6 KB ID:	657558Click image for larger version  Name:	Screenshot_20170721-003248.jpg Views:	1 Size:	22.0 KB ID:	657559Click image for larger version  Name:	Screenshot_20170721-003302.jpg Views:	1 Size:	20.1 KB ID:	657560Click image for larger version  Name:	Screenshot_20170721-003210.jpg Views:	1 Size:	46.5 KB ID:	657561Click image for larger version  Name:	Screenshot_20170721-003325.jpg Views:	1 Size:	19.6 KB ID:	657562Click image for larger version  Name:	Screenshot_20170721-010720.jpg Views:	1 Size:	29.2 KB ID:	657563Click image for larger version  Name:	Screenshot_20170721-010729.jpg Views:	1 Size:	43.0 KB ID:	657566
    And I forgot to mention: The Amlogic codec brightness bug is finally fixed!
      I like this very much but....
      Will NetfliX work? They have issues witch custom rom and root :-)
        Thanks very much for this ROM!!
        Will check it out and patiently looking forward to the upcoming ATV build
        I had started to make myself a custom rooted rom but could not get past the repacking issue for 7.1 so have been waiting for yourself or SC to work you magic on this box!!
          Ok I test it and Netflix works fine
          Thanks voor this rom
            Hi all, would this work on the same box but the S905X version?
              You mean the M8S Pro+? Probably not, but that's on my list. Just waiting for hardware.
                Yea that's the one. Stock is terrible. Can't replace the home launcher and standby/suspend doesn't seem to work properly as completely restarts again on switch on.
                  Hi, just want to ask. Which will you recommend the stock nexus or nano nexus? Thanks
                    The Stock variant includes more stuff, and is more typical of the apps that would be preinstalled for a Google Nexus phone or tablet. The Nano variant is just what I use as a foundation for the TVStock (Android TV) variant, and it's really just the bare essentials.
                      • Included additional keyboard layouts and fixed IR remote "mouse mode"
                        how will apply the update? thanks
                          I also want to ask if the OTA update could be applied through existing update app on factory os?
                            If you're on the OEM firmware, use the Update app (selecting option to wipe data). If you've already installed from the Amlogic burn package, type "reboot recovery" in Terminal and install in TWRP.
                              Did the OTA update but did not wipe data first, box is now bricked with only red light on box and black screen on TV. How can I get it back?
                              • Guest's Avatar
                                Guest commented
                                Editing a comment
                                If you power up with the reset button (pinhole on bottom) pressed, it will take you to TWRP Recovery. From there, you can do a data wipe. Alternatively, you can do a fresh flash from the burn package (.img file) using USB Burning Tool.
