[ROM] Mecool M8S Pro Stock & Nano Nexus ROMs (Android 7.1)
    I have recently bought two mecool m8s pro from gearbest and i had all those problems. After a tough week with speaking with gearbest and installing the firmware they told me 20170707.094011.V0321 it seemed that the problem solved. But after two days it couldn't load and i did a factory reset and i decided to send them back and get the refund. The problem was with the expensive travel. 40 euros for the box which costs 69. Until i found your rom. I installed it successfully thank god even i haven't believed that i could and i will test it for a few days to see how it goes. Thank you very much. Greetings from Greece
      I need your help. As i told you i installed your rom and i have some problems. First of all i had changed my firmware to the m8s pro after contacting with gearbest to 20170707.094011.V0321 via zip file with usb.When i first opened run V.0221. Then i download your file "updated M8Spro V0321 Nano 20170807. Zip and i installed it through usb. It run well although sometimes lost the wifi for seconds and today i installed my apk and suddenly crushed. No reboot nothing. I did wipe data and i make it all over from the beginning. Now i noticed that there are no apk from the m8s pro from factory such as air pin pro or you tube although the first time i installed your rom there were all. I don't care about apks i lost i just wanted to help me to fix it in the right way. I did all the steps with usb because i don't have any laptop or pc. Please help me to set it in the right way because i have one more m8s pro in the box which i have to fix it also. Help!!!!!
        As I wrote in the original post, a data wipe is recommended the first time you install my custom ROM over the OEM firmware. This happens automatically if you install the .img file via USB Burning Tool, but you have to explicitly check the box to do that if using the Updater app with the .zip file. So, when you originally had a mix of OEM apps and Google apps, that was not a desired configuration. Doing a factory reset from Settings will set everything right (or you can enter TWRP recovery and do it there too).
          Thanks for your quick reply. When it crushed with your rom or maybe with my mix of roms as you said i did i opened twrp and in the wipe i did swipe to factory reset. Then it stucked again for a while until to synchronize with my gmail but now it boots ok. So after all my mistakes you think now its ok to start loading my apps? Now i checked in settings that the box runs M8S PRO-userdebug 7.1.1. NMF 26Q 20170524.163713.V0321.
          In the second box which steps should i do for the right way with no mistakes. Thanks for all my friend
            I am gonna definitely need your help. Yesterday it freezed several times and when finally booted successfully the Wi-Fi was very slow. The internet connection was ok because i tested it with my smartphone. Can you give me a solution? Thanks
            • Guest's Avatar
              Guest commented
              Editing a comment
              I'll have an update later today based on the new OEM firmware (20170801.150811.V0321). Maybe that will help.
            #36
            Thanks for your help. Do you suggest to do the procedure using a computer and the usb burning tool because the previous time i did through ota and a usb flash.
            • Guest's Avatar
              Guest commented
              Editing a comment
              Using an Amlogic burn package (.img file) and USB Burning Tool is definitely the preferred flash method. It ensures you have a clean slate, just like from the factory. The OTA update (.zip file) is provided if you don't have a male-to-male Type A USB cable or are just doing an incremental update.
            #37
            Alright i get it. Can you send me the link when you are ready. Also which version of your rom do you suggest?
            • Guest's Avatar
              Guest commented
              Editing a comment
              I recommend you always use the latest release for your hardware. As for the variant (Nano, Stock or TVStock), that's really your preference. Most prefer the pure Android TV experience for their media viewing, and so TVStock is definitely the most popular.
            #38
            I really don't know how to thank you for all your help. I asked for the link because i download from my smartphone and i cannot see what file i download until the transfer its done. I have to borrow a computer to make the procedure right for this time. Thanks again. Goodnight
              New update today, based on the latest OEM build.
              Changelog (20170825):
              • Updated to latest M8S Pro OEM firmware (20170801.150811.V0321)
              • Underlying OEM firmware is now pre-rooted, and so ours is too
              • Latest build from Open GApps (20170825)
              IMPORTANT NOTE:
              This will likely be the last Nexus custom ROM update based on the Mecool M8S Pro OEM firmware. There's a new generic ROM from the factory that we'll be using to target all devices based on Amlogic q201 reference board.
              Here are the advantages:
              • Newer Android Nougat 7.1.2 (NHG47L build)
              • Works with a long list of wireless chipsets, based on both the Qualcomm (Longsys) and Broadcom (AMPAK) driver architectures. To my knowledge, this is the first ROM that works on both.
              • Supports several IR remotes (including OEM from Beelink and Mecool...even when pressing the Power button to cold boot).
              • IR remove codes are NOT stored in the device tree, so they're once again easily customizable in the remote.conf.
              • An excellent selection of video and audio settings at top level, including overscan, HDR, CEC, Dolby, and DTS.
              • Configurable power button, plus press-and-hold pop-up menu with Power Off and Shutdown.
              This is really the "One ROM to rule them all!"...which is why we've been calling it "Precious".
              The disadvantage:
              • There's a bug with Bluetooth audio playback, which makes speakers and headsets basically unusable, but I've been assured that this is already fixed in the next release.
              You can download this new ROM in Nano, Stock and TVStock (Android TV) variants now, if you'd like to try them out.
                Since it comes up as M8S PRO+-userdebug 7.1.1 NMF26Q 20170715.093046.V0321
                I figured it should be done hear, Ohhh Well my Mistake just delete the post.
                BTW File name on the Chine site is MINIMXIII-II_V0321_TVStock-20170730.img
                • Guest's Avatar
                  Guest commented
                  Editing a comment
                  Did you intend to post this to a different forum? What's this got to do with the M8S Pro?
                #41
                Today i installed tv stock rom with usb burning tool. I think i prefer nano version. Although i had some problems such as it lose wifi during google setup and then i couldn't pair my bluetooth mouse. The most important was that i couldn't type to find an apk in the play store. When i pressed the button to search it won't let me to write anything only the choice for speaking. I dont know if i did something wrong. And when i turned it off i couldn't reboot it and either open twrp. It freezed nexus on the screen. Nevertheless now i learned how to use usb burning tool i will try the other versions. Thanks for your interesting. I will try also the firmware for Acemax U2+ TV Box and i will tell you the results. I was thinking to test also the new update from beeling gt1 ultimate...
                I had a similar problem with the first time i tried to use the NANO version. I simply re flash it and tried again and it went through fine second time around. Now I use it on my main Media player all the time togethee with the TV launcher from Awesome Dev.
                Not sure why the Acemax U2+Box post is on this thread. Totaly different box and uses the S905 chip instead of the S912 as in the M8S Pro. Probably wont get far trying to use that firmware.
                  Ok i will make a try tomorrow. About the beelink update do you know anything? Because i had bought a beelink gt1 for my father but because we live in different cities i worked only for a day and now he has some problems with his bluetooth mouse he couldn't pair it so i must do something with the beelink also later.
                  • Guest's Avatar
                    Guest commented
                    Editing a comment
                    Could you please move the Beelink question to a forum for that device?
                  #44
                  If you didn't pick this up from earlier comments, I picked up a couple of bugs when I grabbed newer versions of Google Search (Katniss) and the Android TV Package Installer (CanvasPackageInstaller) from the latest factory ROMs posted for the Nexus Player. I've since reverted to the previous versions, and it seems to have fixed the issues.
                  Since I was a bit time constrained, there was no official updated release. If you use the old links, you'll pick up the changes.
                    Alright i will try it tomorrow. Thanks
