Do i have to do this change "ro.product.device == "M8SPRO", before i flash?
[ROM] Mecool M8S Pro Stock & Nano Nexus ROMs (Android 7.1)
One strange thing i noticed after the update (as told in #137).
i use the last version of FTMC for some months now without any issue. Yesterday, it was the first time i used it (after the update) and the UI of ftmc is in 1280x720 resolution, so all videos i tried (no matter what resolution they are), played in a small square , upleft on my 43" uhd tv screen. I cannot change the ui into fhd or uhd because there is no option in ftmc settings. The same happened in SPMC, but it was possible to change the ui , so the video played in full screen. No problems detected in original kodi. Is there something i can do, because ftmc is my favorite?
Thank you.
P.s. I unistalled and installed ftmc some times, reboot the box some times, i disconnected and connected hdmi sometimes but no fix!
Originally posted by zenix View PostOne strange thing i noticed after the update (as told in #137).
Thank you.
P.s. I unistalled and installed ftmc some times, reboot the box some times, i disconnected and connected hdmi sometimes but no fix!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I use on the same box kodi, spmc & ftmc with three different builds (testing and playing) and i like ftmc more. Until know, it's useless.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Magendanz View PostChangelog (20171103):- Updated to latest M8S Pro OEM firmware (20171030.162112.V0619)
- Removed attempt to launch voice assist on Back button long press. (Only valid for watches)
- Latest build from Open GApps (20171103)
- Nano Variant: BURN PACKAGE (915MB IMG file), OTA UPDATE (467MB ZIP file)
- Stock Variant: BURN PACKAGE (1.42GB IMG file), OTA UPDATE (801MB ZIP file)
- Flash burn package with Amlogic USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.2
I have ordered the - "M8S Pro L" version of the box, don't sure when I will receive it, but when I do, I want to burn your stock rom right away... So, I just wanted to ask, when will you release a version for "M8S Pro L" also? Thanks.
#142.1Guest commented15 November 2017, 22:22Editing a commentIt's already available here: http://freaktab.com/forum/tv-player-...android-tv-7-1
I'm just copying Nano and Stock variants up for the M8S Pro L now. Give me about an hour to get it posted.
UPDATE: It's now posted: http://freaktab.com/forum/tv-player-...android-tv-7-1Last edited by Guest; 16 November 2017, 07:45.
I downloaded the last version of LiveWallpapersPicker.apk and copied it into the /system/app and gave the right permisions (rw-r-r), with es explorer but anytime i am trying to set a livewall paper, it crashes. Am i doing something wrong? What other version should i try? Any tip?
Do you think is a firmware problem or it can be fixed somehow?
Thank you
Hello! Can someone tell me how to properly activate sleep/standby function with 0321 Stock version of this ROM, because now when I press the power button on my remote it turns the box completely off...
And my other question is - which rom is better 0321 or 0619?
Because with OEM 0619 I have spontaneous artifacts in video playing (Kodi, media player) , but not in 0321...
Guest no, I haven't had any luck with the rom you pointed me @ post #130.1
Both script edited attempts, and any others throw an error code 7.
All I can think is I need to remove any reference to the buildprop from the update? Or is it possible to find my buildprop parameters in my remaining files.
Confirming what specific device detail is the target.
Idk if that's possiprobly? I've read a bit re: e#7, but hoping for your direction.
++ Again, I believe I repacked zip for "m8sPro" properly....
at least once ?
I've flashed M8S_PRO-V0619_Nano-20171103.img everything seems to be working ok so far but I have come across a problem with live wallpapers.
I have installed several different live wallpapers.
They install without errors and come up in the wall paper picker for selection but when I click on them I get "app not installed" error.
Anyone else getting this???
There are currently 5116 users online. 1 members and 5115 guests.
