[ROM] Mecool M8S Pro Stock & Nano Nexus ROMs (Android 7.1)
Guest
Changelog (20180310):- Updated to latest M8S Pro L OEM firmware (20180205.111652.V0928)
- Wake from sleep is now working, and taking the expected 2-3 seconds.
- New build of Mali driver that supports OpenGL 3.2 + AEP
- Latest build from Open GApps (20180310)
- Clicking on Vision Settings in the setup wizard will launch an unsupported activity in Settings.
- You can enable the nav bar in Settings->Display->Statusbar, but may need to toggle back and forth before it will show.
- Nano Variant: BURN PACKAGE (925MB IMG file), OTA UPDATE (476MB ZIP file)
- Stock Variant: BURN PACKAGE (1.42GB IMG file), OTA UPDATE (806MB ZIP file)
Sure, Mali are no wonder, but the moonlight performance in this box was garbage compared to other s912 based boxes. so the issue has to be in the firmware.
there's a youtube reviewer that tests that specific part too and I thought he was a big liar when he said most s912 boxes are perfect for Moonlight gamestreaming.
Few weeks ago he got one of these L pro boxes to test too and he notice the same thing - very laggy although it gets good latency decoding numbers.
Originally posted by zenix View PostCant update with twrp. Error 7.
is the same problem with updater file?
Looks like you installed that old version with the ("M8S_PRO") device name. (http://freaktab.com/node/683014) I've modified the updater script on the current releases to now check for either "M8SPRO" or "M8S_PRO", and so you shouldn't see the problem anymore. Files are syncing on OneDrive now, so give it about 15 minutes. Since the content of the ROM is identical, I'm just replacing all tree OTA Updates (Nano, Stock & TVStock) and the links won't change.
so, I tried new version and still Error:7, but I already know the reason - my build.prop (experiment image M8S PRO on the Shiningworth All-in-One firmwar from post #255 )contain
Code:ro.product.device=M8S
EDIT:
so, I edited my build.prop and now OTA update successfully works...Last edited by bolek; 12 March 2018, 17:12.
Hi Guys! First at all, thanks Guest for this awesome work!!! You`re brilliant!
I`ve been reading frow a few pages before ask here. My doubt is, I have the Mecool M8S Pro, not the "L" model. My device is DRM licensed HDCP 1.x, so I can see NetFlix and many others streaming apps that require the license. I`ve never touched in the Videostrong stock ROM, in the truth, it works well here... But I want to test the Nano variant from Guest ...
If I update will I lose the license?
Can I flash the latest ROM via OTA posted here via the OTA APP provided by Videostrong?
Any chance that any oher problem?
Sorry for the noobies question...
Originally posted by allandacruz89 View PostHi Guys! First at all, thanks Guest for this awesome work!!! You`re brilliant!
Originally posted by tehcno View PostHi, everybody.can someone tell me?put Nano Nexus ROMs (Android 7.1).from February.a week later, put the update on OTA. And then after that, if you send the console to sleep, after turning on the wifi does not connect.how to solve the issue?
There are currently 1708 users online. 1 members and 1707 guests.
