X96 Mini TV Box Amlogic S905W + Android 7.1.2 + Quad-core Cortex-A53 + 4K VP9 H.265
Originally posted by tolb View Posthttps://yadi.sk/d/AaNjRSHi3NrjQ5 from 28.08.17.
In fact, I tried to install Supersu on my "x96 mini box" (from Playstore) and then... i had an issue with a boot loop.
How to fix this ? (and reinstall firmware ?) :
1° Restart your "x96 mini box".
2° Immediatly when it boots, you need to take something (for example a thumbtack) to use the reset button of your X96 box tv. For information, the button is hide inside the "AV" hole (look the photo i upload to understand)
3° When it succeeds, you will be in "Recovery Mode".
4° Go here https://yadi.sk/d/AaNjRSHi3NrjQ5. Then, choose "Sdcard" and Download "p281-ota-root.zip".
5° Copy "p281-ota-root.zip" on your micro sd card.
6° Insert your micro sd card in your "X96 mini box tv".
7° In the "Recovery Mode" (cf. 3°), choose "Apply Update from external storage".
8° Search "p281-ota-root.zip" on your sd card and install it.
9° It will reboot....and then.... perfect, it's works !!!!!
PS: I hope my explications could help some people
PS2: If you see errors in my english, say it ! (like that, i could improve it)You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by MDashK View PostAwesome info! Thanks a bunch @gamzone.
BTW; were you able to root the device in the end?
But you need to know two things :
- When you start the "X96 mini" for the first time, the firmware is pre-root (nb: but i did not find with titanium backup the software that they were used for this root....).
- When you reinstal the firmware "p281-ota-root.zip", it is also pre-root (because it is the same firmware).
In conclusion, this box is always pre-root...and you can not change that.
Originally posted by gamzone View Post
With Supersu ? No, i was not able to root this box.
Originally posted by nickzeptepi View PostI found with SuperSU it says you must update and it's the update that bootloop the box.
Oh really you found the software ? I did not pay attention before the reboot (and the bootloop).
So, what's the name of the root's software pre-installed on x96 mini?
PS: Someone know a custom firmware ANDROID TV for x96 mini ?
(Nb: x96mini = AMlogic s905w)
thanks in advance !
I'm also trying to get rid of this device. I came across this topic here:
I follow the steps, but it does not work to install SuperSu. Has anyone of you managed to install SuperSuS?
I'm trying to change product.model and ro.product.brand so I can install Teamviewer on it. My purpose is to edit the build.prop file with the program in the dwarf because when I edit it with adb pull and push the box becomes brick.If you have any advice on how to become, please share
Originally posted by MDashK View PostAnyone knows where I can get a firmare with android 6 for this?
Or better... How to root this one?Last edited by sappy; 27 October 2017, 09:22.
Originally posted by sappy View Post
Root checker said that it has root and Busy Box is installed, but DO NOT install SuperSu aplication and if you do... do not update su binary - I did - and I have a bootloop - so if anyone has FW .img for USB Burning tool - to reflash for this TV Box.., I would be grateful...
This one said - it has - https://play.google.com/store/apps/d...ps.rootchecker - and I first did not check Freaktab for possible problems.., and Box is in the boot logo (bootloop).., so now I am downloading FW on this page - I see that in the package "170828" there is also "aml_upgrade_package.img" so anybody flash this with USB Burning tool - successfully !??
And for overtheating there is also very cheap solutions from from ****...
And I tried "aml_upgrade_package.img" with USB Burning tool - flashed successfully - about 4 minutes...and back to business..., so who have male to male usb cable - this is easier than with sd card...Last edited by sappy; 27 October 2017, 11:29.
There are currently 2295 users online. 0 members and 2295 guests.
