X96 Mini TV Box Amlogic S905W + Android 7.1.2 + Quad-core Cortex-A53 + 4K VP9 H.265
is this X96 and different to this one https://www.aliexpress.com/item/Genu...311.0.0.N0Qy1H ????
Originally posted by lohtse View Postis this X96 and different to this one https://www.aliexpress.com/item/Genu...311.0.0.N0Qy1H ????
[QUOTE=jiangsai0703;n706830]Originally posted by Adam1180 View PostThanks. It works fine. Is any way to unroot the box? Some applications are not working now. Regards
Some customers need root, and some don't need it, it's really hard
Also is the bottom navigation bar still missing in your latest firmware?
This is an example of a navigation bar(the black bar on the bottom), it's missing in your Android 7 ROM.
I have the problem that my ethernet is not recognized. WLAN works perfectly. Even when you turn off the WLAN, he does not recognize the LAN. Always shows distress and when I click on it nothing happens. It worked very briefly, but not since. Router and Ethernet is fine. I wrote a message to Gearbest where I received an answer that the error was known. Do you have problems with that? I think the RJ45 socket is not defective. Even setting a fixed IP on Static did not bring any success. Maybe someone of you has already solved the problem?
It is the current x96 mini (2018-02-07) with the system update from 2018-01-25. Even with the delivered firmware from December 2017 the Ethernet did not work.
bugmenot2
I think you need the firmware from here.
https://www.chinagadgetsreviews.com/...ni-tv-box.html
Android 7.1.2
Securitypatch Level Aug. 1, 2017
Build 20171009
After that there are two system updates that you can play. Last stand would be then 20180125
How to play the firmware you know, hopefully
i have a problem with my Android box x96 mini. I have connected it to my Sony bravia kdl-40ex600. Often the collors goes green. I changed all the settings in the TV or android and the problem is still. Please can some one help to resolve this issue?
thank you in advance
ErvinYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
There are currently 3050 users online. 0 members and 3050 guests.
