X96 Mini TV Box Amlogic S905W + Android 7.1.2 + Quad-core Cortex-A53 + 4K VP9 H.265
Originally posted by hcardoso483 View Post
The firmware you are using is not for your device thats thats why it stops, try the i sent check ether the tanix 3 or the x96mini same specs will workOriginally posted by hcardoso483 View Post
i've tried all these roms but they all blocs, and some ones gives a green screen when i begin :
- TX3Mini-20171107_Tanix-Box_com (1.2Gb)
- W95_705N0 (950Mb)
- P281_6051P_8G1G2G_20171129 (753 Mb)
- aml_upgrade_package (1.50Gb)
- aml_upgrade_package (1.17Gb)
- MXQ PRO 905w_ssv6051_8g1g2g_171101_SD_USB (909Mb)
- cyx_A95X-R2_905x_7.1_9082c_16g2g_180102_SD_USB (938Mb)
- ATVXperience-v2A (1.32Gb)
Originally posted by zadryl View Post
hello friend,
- W95_705N0 (950Mb)
when i try to update with recovery mode it gives me errors (joined foto).
i've tried it, but it gives me this error (joined foto)
I know it may loke a stupid question but what device are you trying to flash, i vound verry strange the trobles your're getting, please tell us what device are you trying to flash seams that there is a software hardware inconpability...
its a tvbox x96 mini (S905W) 2GB - 16GB
hello friend,
Get the x96mini factory firmware on your pc download and instal the world cup driver download the amlogic usb burn utilaty connect the device to pc with the male to male cable use the white usb port on the device load the firmware and start the proccess in order to get your device back, then if you still wanna play with custom firmware my advice is use always the burn card method and untick the erase bootloader option unless you are changing android version DO NOT TICK THE ERASE BOOTLOADER OPTION, good luck let me now after
hello friend,
USB urning tool
https://mega.nz/#!6N4RDLjb!c2XRwu8gL...-chLJZ17muv4S4
worldcupdriver
https://mega.nz/#!XEYQHYba!nOVmBgoG9...-e7MvgAUjCsRMY
Firmware
https://mega.nz/#!KBYD2R6L!2rTmHTb_k...F8W0I48JTioms8
after installin this one there is an update use the update app to do it for you it works, new update brings root as well
you need to extract all rar files and you will get the proper file
heres an extra the burn card maker for flashing with card method
https://mega.nz/#!PIpkiKZb!dIv86A60-...AnL-xIGAcwCrhc
make sure your downloads don't get corrupted
As Found :
X96 MINI ANDROID 7.1.2 AMLOGIC S905W 4K TV BOX FIRMWARE UPDATE 20180512
Source: blog.geekbuying
here is what you need,
USB urning tool
worldcupdriver
Firmware
make sure your downloads don't get corruptedOriginally posted by hcardoso483 View Post
USB urning tool
worldcupdriver
Firmware
first of all, thanks you for your help
i tried first burn method with the file you gived me, but upgrading stops in the begining.
and when i use the second method (booting device with zip file update, it stops in the middle of the operation.
and using usb burning tool, it blocks in formatting 7% and if i untick erease flash, it blocks at 8% download aml...
i think that this box is died
There are currently 3314 users online. 0 members and 3314 guests.
