X96 Mini TV Box Amlogic S905W + Android 7.1.2 + Quad-core Cortex-A53 + 4K VP9 H.265
Originally posted by marcolan View Post
I can make a precisation because it happened to me:
If I don't change in "view" tab of usb burning tool temperature range fron 20-40 to 20-60 system gives me an error at 9/%.
When you change that value all goes ok.
I put latest firmware in the box but I don't know why resolution doesn't go over 720. It says 1080 but if you go into KODI it says 720 as it appears to my eyes.
Any ideas?
Code:adb shell wm size 1920x1080
then,if the words are too small,type:
Code:adb shell wm density 240
Although it is a bit late, I will be happy if it is helpful.
Although the purpose of my visit here is to repair my broken box, and here is no answer.
My English is poor,Sorry!
Any ideas?
Tips: usage:wm [subcommand] [options]
wm size [reset|WxH]
wm density [reset|DENSITY]
wm overscan [reset|LEFT,TOP,RIGHT,BOTTOM]
wm size: return or override display size.
wm density: override display density.
wm overscan: set overscan area for display.
Although the purpose of my visit here is to repair my bricked box,a S905X box named “Meizu Box B601”from China,the same problem with only one USB and no SD card slot , here is no answer.
Has anyone run into this problem? The x96 mini doesnt appear to be able to keep the time and date. No internal battery. Maybe a lot of Android boxes are this way.
At any rate I had set up a box for a special purpose for some old people that dont have internet. So when the box boots up it automatically defaults to 8:00am January 1, 2014.
They are using an app that gives them reminders and articles based on a calendar. But it now thinks its 2014 and reminds them to do things that they should have done 5 years ago, not very useful.
You can manually set it, but once you cycle power it goes right back to that date.
Does anyone know of any kind of fix for this whatsover aside from having wifi always available when booting it up? A special app? Adding an internal battery? Adding GPS, heck I cant think of a good way, can you?
Originally posted by Slickpuss View PostHas anyone run into this problem? The x96 mini doesnt appear to be able to keep the time and date. No internal battery. Maybe a lot of Android boxes are this way.
Originally posted by Krocolatoz View Posthi guys can u guys guide me how to flash x96 mini, i just bricked my x96 mini after flashing it using amlogic burning tool flashing atv9 from yandisk.
right now it only flash red led light..
help me please
Originally posted by Elenick View PostCan someone help me unbrick my x 96 mini with stock firmware or anything else? It shows only red light and at usb burner stucks at 1% says something about ddr
????Please help
Do you have such a mistake https://t.me/zzz111kiev/313 ?
There are currently 1916 users online. 0 members and 1916 guests.
