X96 Mini TV Box Amlogic S905W + Android 7.1.2 + Quad-core Cortex-A53 + 4K VP9 H.265
Romcode/Initialize DDR/Download buffer/Read item data failed thgis is the error i get and on a laptop i get parsing error without loading the img file the photo is wrong im sorry i dont know how to delete it it stuck on 1% with the error i said here in the comment pls helpYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
If you have a problem with the device, in the video I will tell you how to fix it. https://youtu.be/-KKnwQ2ux0UStep-by-step smart box firmware with Android TV, Android 7 and atvXperience firmware. How to restore TV box in case of unsuccessful firmware.
Originally posted by zzz111 View PostIf you have a problem with the device, in the video I will tell you how to fix it. https://youtu.be/-KKnwQ2ux0U
i have a bricked x96 mini. its stuck on the red light and burning stops at 1%. can u send me a link of original firmware ?
Originally posted by homeboy228 View Post
hi,
Hi! Under my video on the YouTube channel there are all the links. Write me where to send the password for the firmware in the comments to the video on the YouTube channel. And I will send it to you.
Thank you
Originally posted by chenteparao View PostHi, I bought a x96mini some days ago for run Corelec, today bought the “same” device for my brother but not boot. I install AIDA64 in both devices and old X96mini has a difference, it say p281 in board, while new device say p282 in board. Do you know how to run in this new device? Thanks.
Are the Androld firmware versions the same?
x96mini giving solid red light only .i'm trying to flash it with almost all usb burning tools but stuck on 1 % romcode/initialize ddr/download buffer/read item data failed error
and device is detected through nand short pins.
[20:25:12 856][Global][Inf]--Scan usb device
[20:25:12 856][Global][Inf]--Aml scan WorldCup Device
[20:25:12 859][Global][Inf]--Host: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B34
[20:25:12 859][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_3b34&subsys_00011179& rev_06#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[20:25:12 859][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&35a55fd8&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[20:25:12 860][Global][Inf]-------->[Port0]USB#VID_8087&PID_0020#5&f3d498c&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[20:25:12 860][Global][Inf]---------->[Port0]NoDeviceConnected
[20:25:12 860][Global][Inf]---------->[Port1]NoDeviceConnected
[20:25:12 860][Global][Inf]---------->[Port2]NoDeviceConnected
[20:25:12 860][Global][Inf]---------->[Port3]NoDeviceConnected
[20:25:12 862][Global][Inf]---------->[Port4]Other device
[20:25:12 862][Global][Inf]---------->[Port5]NoDeviceConnected
[20:25:12 862][Global][Inf]---------->[Port6]NoDeviceConnected
[20:25:12 862][Global][Inf]---------->[Port7]NoDeviceConnected
[20:25:12 862][Global][Inf]-------->[Port1]NoDeviceConnected
[20:25:12 863][Global][Inf]--Host: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B3C
[20:25:12 863][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_3b3c&subsys_00011179& rev_06#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[20:25:12 863][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&1288e406&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[20:25:12 863][Global][Inf]-------->[Port0]USB#VID_8087&PID_0020#5&15f143a1&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[20:25:12 864][Global][Inf]---------->[Port0]NoDeviceConnected
[20:25:12 864][Global][Inf]---------->[Port1]NoDeviceConnected
[20:25:12 864][Global][Inf]---------->[Port2]NoDeviceConnected
[20:25:12 864][Global][Err]---------->[Port3]Error connect status 2
[20:25:12 864][Global][Inf]---------->[Port4]NoDeviceConnected
[20:25:12 864][Global][Inf]---------->[Port5]NoDeviceConnected
[20:25:12 864][Global][Inf]-------->[Port1]NoDeviceConnected
[20:25:12 864][Global][Inf]--Scan USB host controller complete
[20:25:12 864][Global][Inf]--Update data center with HubMap
[20:25:19 302][Global][Inf]--User click open button
[20:25:22 607][Global][Inf]--Image path E:\Final apks\atv firm\s905w_atvXperience_v2FF.img
[20:25:42 857][Global][Inf]--Parsing burning package
[20:25:42 858][Global][Inf]--Load configuration file C:\Program Files (x86)\Amlogic\USB_Burning_Tool\temp
[20:25:42 859][Global][Inf]--Parse burning configuration file C:\Program Files (x86)\Amlogic\USB_Burning_Tool\temp\burn_config.xm l
[20:25:42 915][Global][Inf]--Get burning key
[20:26:08 663][Global][Inf]--User click start button
[20:26:08 665][Global][Inf]--SetErase
[20:26:08 665][Global][Inf]--Enable burning 1
[20:26:08 665][Global][Inf]--Scan usb device
[20:26:08 665][Global][Inf]--Aml scan WorldCup Device
[20:26:08 711][Global][Inf]--Host: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B34
[20:26:08 711][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_3b34&subsys_00011179& rev_06#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[20:26:08 711][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&35a55fd8&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[20:26:08 711][Global][Inf]-------->[Port0]USB#VID_8087&PID_0020#5&f3d498c&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[20:26:08 711][Global][Inf]---------->[Port0]NoDeviceConnected
[20:26:08 711][Global][Inf]---------->[Port1]NoDeviceConnected
[20:26:08 711][Global][Inf]---------->[Port2]NoDeviceConnected
[20:26:08 711][Global][Inf]---------->[Port3]NoDeviceConnected
[20:26:08 712][Global][Inf]---------->[Port4]Other device
[20:26:08 712][Global][Inf]---------->[Port5]NoDeviceConnected
[20:26:08 712][Global][Inf]---------->[Port6]NoDeviceConnected
[20:26:08 712][Global][Inf]---------->[Port7]NoDeviceConnected
[20:26:08 712][Global][Inf]-------->[Port1]NoDeviceConnected
[20:26:08 713][Global][Inf]--Host: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B3C
[20:26:08 713][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_3b3c&subsys_00011179& rev_06#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[20:26:08 713][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&1288e406&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[20:26:08 713][Global][Inf]-------->[Port0]USB#VID_8087&PID_0020#5&15f143a1&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[20:26:08 713][Global][Inf]---------->[Port0]NoDeviceConnected
[20:26:08 713][Global][Inf]---------->[Port1]NoDeviceConnected
[20:26:08 713][Global][Inf]---------->[Port2]NoDeviceConnected
[20:26:08 713][Global][Err]---------->[Port3]Error connect status 2
[20:26:08 713][Global][Inf]---------->[Port4]NoDeviceConnected
[20:26:08 714][Global][Inf]---------->[Port5]NoDeviceConnected
[20:26:08 714][Global][Inf]-------->[Port1]NoDeviceConnected
[20:26:08 714][Global][Inf]--Scan USB host controller complete
[20:26:08 714][Global][Inf]--Update data center with HubMap
[20:26:14 225][Global][Inf]--Catch DBT_DEVICEARRIVAL
[20:26:14 226][Global][Inf]--Scan usb device
[20:26:14 226][Global][Inf]--Aml scan WorldCup Device
[20:26:14 228][Global][Inf]--Host: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B34
[20:26:14 228][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_3b34&subsys_00011179& rev_06#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[20:26:14 228][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&35a55fd8&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[20:26:14 228][Global][Inf]-------->[Port0]USB#VID_8087&PID_0020#5&f3d498c&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[20:26:14 228][Global][Inf]---------->[Port0]NoDeviceConnected
[20:26:14 228][Global][Inf]---------->[Port1]NoDeviceConnected
[20:26:14 229][Global][Inf]---------->[Port2]\\?\usb#vid_1b8e&pid_c003#6&10e24d81&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[20:26:14 229][Global][Inf]---------->[Port3]NoDeviceConnected
[20:26:14 230][Global][Inf]---------->[Port4]Other device
[20:26:14 230][Global][Inf]---------->[Port5]NoDeviceConnected
[20:26:14 230][Global][Inf]---------->[Port6]NoDeviceConnected
[20:26:14 230][Global][Inf]---------->[Port7]NoDeviceConnected
[20:26:14 230][Global][Inf]-------->[Port1]NoDeviceConnected
[20:26:14 231][Global][Inf]--Host: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B3C
[20:26:14 232][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_3b3c&subsys_00011179& rev_06#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[20:26:14 232][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&1288e406&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[20:26:14 232][Global][Inf]-------->[Port0]USB#VID_8087&PID_0020#5&15f143a1&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[20:26:14 232][Global][Inf]---------->[Port0]NoDeviceConnected
[20:26:14 232][Global][Inf]---------->[Port1]NoDeviceConnected
[20:26:14 232][Global][Inf]---------->[Port2]NoDeviceConnected
[20:26:14 232][Global][Err]---------->[Port3]Error connect status 2
[20:26:14 232][Global][Inf]---------->[Port4]NoDeviceConnected
[20:26:14 232][Global][Inf]---------->[Port5]NoDeviceConnected
[20:26:14 232][Global][Inf]-------->[Port1]NoDeviceConnected
[20:26:14 233][Global][Inf]--Scan USB host controller complete
[20:26:14 233][Global][Inf]--Update data center with HubMap
[20:26:14 233][Global][Inf]--Insert new hub2
[20:26:14 233][Global][Inf]--Update hub2 device data
[20:26:14 252][Global][Inf]--Update HUB2-1
[20:26:14 252][HUB2-1][Inf]--Update device path
[20:26:14 252][Global][Inf]--Update HUB2-2
[20:26:14 252][HUB2-2][Inf]--Update device path
[20:26:14 252][Global][Inf]--Update HUB2-3 \\?\usb#vid_1b8e&pid_c003#6&10e24d81&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[20:26:14 252][HUB2-3][Inf]--Update device path
[20:26:14 263][Global][Inf]--Burning thread HUB2-3 start
[20:26:14 263][Global][Inf]--Begin thread for HUB2-3
[20:26:14 263][Global][Inf]--Update HUB2-4
[20:26:14 263][HUB2-4][Inf]--Update device path
[20:26:14 263][Global][Inf]--Update HUB2-5
[20:26:14 263][HUB2-5][Inf]--Update device path
[20:26:14 263][Global][Inf]--Update HUB2-6
[20:26:14 263][HUB2-6][Inf]--Update device path
[20:26:14 263][Global][Inf]--Update HUB2-7
[20:26:14 263][HUB2-7][Inf]--Update device path
[20:26:14 263][Global][Inf]--Update HUB2-8
[20:26:14 263][HUB2-8][Inf]--Update device path
[20:26:14 281][Global][Inf]--Burning thread HUB2-3 begin run
[20:26:14 282][HUB2-3][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#6&10e24d81&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x00000838
[20:26:14 333][HUB2-3][Inf]--CloneImageProxy
[20:26:14 354][HUB2-3][Inf]--Connect path=Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B34/P0/P0/P2
[20:26:14 354][HUB2-3][Inf]--Start burning...
[20:26:14 405][HUB2-3][Inf]--------------ERASE BOOTLOADER------------
[20:26:14 448][HUB2-3][Inf]--2-4-0-0
[20:26:14 480][HUB2-3][Inf]-------------Download DDR.USB-----------
[20:26:14 480][HUB2-3][Inf]--2-4-0-0
[20:26:14 480][HUB2-3][Inf]--Control write pll reg1 0xd9000000:0x000000b1
[20:26:14 982][HUB2-3][Inf]--Control write pll reg1 0xd9000000:0x00005183
[20:26:15 483][HUB2-3][Inf]--Write initial succeed
[20:26:15 483][HUB2-3][Inf]--Upload encrypt at 0xc8100228
[20:26:15 483][HUB2-3][Inf]--ulValue = 0xbdfc31bc
[20:26:15 483][HUB2-3][Inf]--File change to DDR_ENC.USB
[20:26:15 483][HUB2-3][Inf]--Read encrypt value succeed
[20:26:15 495][Global][Err]--DDR_ENC.USB
[20:26:15 495][HUB2-3][Err]--Read item data error, code -1
[20:26:15 703][HUB2-3][Err]--[0x10103005]Romcode/Initialize DDR/Download buffer/Read item data failed
[20:26:15 725][HUB2-3][Inf]--Close device handle 0x00000838
[20:26:20 282][Global][Inf]--Catch DBT_DEVICEREMOVECOMPLETE
[20:26:20 285][Global][Inf]--Scan usb device
[20:26:20 285][Global][Inf]--Aml scan WorldCup Device
[20:26:20 289][Global][Inf]--Host: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B34
[20:26:20 289][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_3b34&subsys_00011179& rev_06#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[20:26:20 289][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&35a55fd8&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[20:26:20 290][Global][Inf]-------->[Port0]USB#VID_8087&PID_0020#5&f3d498c&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[20:26:20 290][Global][Inf]---------->[Port0]NoDeviceConnected
[20:26:20 290][Global][Inf]---------->[Port1]NoDeviceConnected
[20:26:20 290][Global][Inf]---------->[Port2]NoDeviceConnected
[20:26:20 290][Global][Inf]---------->[Port3]NoDeviceConnected
[20:26:20 291][Global][Inf]---------->[Port4]Other device
[20:26:20 291][Global][Inf]---------->[Port5]NoDeviceConnected
[20:26:20 292][Global][Inf]---------->[Port6]NoDeviceConnected
[20:26:20 292][Global][Inf]---------->[Port7]NoDeviceConnected
[20:26:20 292][Global][Inf]-------->[Port1]NoDeviceConnected
[20:26:20 295][Global][Inf]--Host: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B3C
[20:26:20 296][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_3b3c&subsys_00011179& rev_06#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[20:26:20 296][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&1288e406&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[20:26:20 296][Global][Inf]-------->[Port0]USB#VID_8087&PID_0020#5&15f143a1&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[20:26:20 296][Global][Inf]---------->[Port0]NoDeviceConnected
[20:26:20 296][Global][Inf]---------->[Port1]NoDeviceConnected
[20:26:20 297][Global][Inf]---------->[Port2]NoDeviceConnected
[20:26:20 297][Global][Err]---------->[Port3]Error connect status 2
Please check it
Chip is samsung 628
Please check it
Chip is samsung 628
I dont know, Im really a noob with this devices, how do I know how to do what you tell me to post it?
You will have to open up the box to check the components on the board. Again, see the first posts on this thread where you can find a teardown showing all the components on the board and what names they have.
Hey guys long time away, some times life plays some trics, anyway i'm back just found something rather interesting for all x96 s905w devices maybe you guys already know about it maybe not it's an android tv 9 build working flowesly great rom, unfortunately i don't know who the developer is, maybe the best rom for this box so far heres a link where i found it, i was able to flash it at the 3rd attempt https://www.youtube.com/watch?v=YyLnoWREWYg guive the man som likes... keep healthy everybody...
Originally posted by hcardoso483 View PostHey guys long time away, some times life plays some trics, anyway i'm back just found something rather interesting for all x96 s905w devices maybe you guys already know about it maybe not it's an android tv 9 build working flowesly great rom, unfortunately i don't know who the developer is, maybe the best rom for this box so far heres a link where i found it, i was able to flash it at the 3rd attempt https://www.youtube.com/watch?v=YyLnoWREWYg guive the man som likes... keep healthy everybody...
There are currently 2631 users online. 1 members and 2630 guests.
