X96 Mini TV Box Amlogic S905W + Android 7.1.2 + Quad-core Cortex-A53 + 4K VP9 H.265
I have this box for a month, and I regret. Every day I have reboots with skewed screen (hw reboot helps), my tv reports 'invalid formats' from time to time. I tried to switch through resolutions and colorspaces and nothing. Is it a buggy box or a faulty unit? I'm using stock fw. Maybe some custom rom would help?
My mxiii-g worked more fluently.
I bricked with my X96 MINI while flashing the update firmware using an SD card. I used Burn_Card_Maker to make an SD card for the update, but unfortunately, the X96 Mini LED turns red and the box does not boot, then I try to use the PC USB_Burning_Tool and my X96mini is detected by USB_Burning_Tool
But It stops at 1% with ]--[0x10103005]Romcode/Initialize DDR/Download buffer/Read item data failed
Error in all versions of the USB burning tool
Only version 2.0.1 shows 1% low_power failed and the log is as follows
[16:34:08 696][HUB1-4][Inf]--Start burning...
[16:34:09 211][HUB1-4][Inf]--------------ERASE BOOTLOADER------------
[16:34:09 211][HUB1-4][Inf]-- low_power
[16:34:13 368][Global][Inf]--User click refresh button
[16:34:39 212][HUB1-4][Err]--IOCTL_BULK_CMD_Handler ret=-116,bulk_cmd= low_power error_msg=libusb0-dll:err [control_msg] sending control message failed, win error: The I/O operation has been aborted because of either a thread exit or an application request.
One thing I have not tried yet is the short NAND method because my box is shown on the USB burning tool.
Please help me to fix this device. I have tried many ways to flash the ROM using USB burning tools and sd card maker tool but no succeed so far.You may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
Originally posted by hcardoso483 View Post
here is what you need,
USB urning tool
https://mega.nz/#!6N4RDLjb!c2XRwu8gL...-chLJZ17muv4S4
worldcupdriver
https://mega.nz/#!XEYQHYba!nOVmBgoG9...-e7MvgAUjCsRMY
Firmware
https://mega.nz/#!KBYD2R6L!2rTmHTb_k...F8W0I48JTioms8
after installin this one there is an update use the update app to do it for you it works, new update brings root as well
you need to extract all rar files and you will get the proper file
heres an extra the burn card maker for flashing with card method
https://mega.nz/#!PIpkiKZb!dIv86A60-...AnL-xIGAcwCrhc
make sure your downloads don't get corrupted
If I don't change in "view" tab of usb burning tool temperature range fron 20-40 to 20-60 system gives me an error at 9/%.
When you change that value all goes ok.
I put latest firmware in the box but I don't know why resolution doesn't go over 720. It says 1080 but if you go into KODI it says 720 as it appears to my eyes.
Any ideas?
Originally posted by Jami View PostI bricked with my X96 MINI while flashing the update firmware using an SD card. I used Burn_Card_Maker to make an SD card for the update, but unfortunately, the X96 Mini LED turns red and the box does not boot, then I try to use the PC USB_Burning_Tool and my X96mini is detected by USB_Burning_Tool
Have you changed USB port in PC?
Or another PC?
It seems an error due to low power perhaps in USB port.
Or another PC?
Or another PC?
I will try again with another PC and share the result with you guys, thanks for the moment
I can make a precisation because it happened to me:
Any ideas?
Thank you marcolan, I will try again and let you know.
Yes, I changed the USB port in the PC and also change the cable but the result was the same.
1 connect the USB to PC cable
2 when you see the device listed in the flash tool plug in the power cable too
3 press start to flash operation
Any ideas?
Unfortunately this device is 720p and not 1080p as advertised there are some custom roms that can make it to output 1080p but no more than that, check this forum
I am almost sure that kd indicated 1080 60hz (i tried also to change in 50hz without result).
When I started to upgrade things changed and now that I'm "update" it is 720, but I am sure before it was fullhd.
I have bought another one today and if it will come with that firm I will post here.
There are currently 4162 users online. 0 members and 4162 guests.
