X96 Mini TV Box Amlogic S905W + Android 7.1.2 + Quad-core Cortex-A53 + 4K VP9 H.265
Originally posted by erw1n View Posti have a problem with my Android box x96 mini. I have connected it to my Sony bravia kdl-40ex600. Often the collors goes green. I changed all the settings in the TV or android and the problem is still. Please can some one help to resolve this issue?
thank you in advance
Ervin
I do not know what X96 Mini I have, but I broke installation with Super SU. I reinstalled succesfully Tanix TX3 mini firmware for it. Can't understand why X96 mini maker can't share own firmware as Tanix do. Next TV Box will be Tanix, even it cost more.
http://www.tanix-box.com/download-vi...mage-20170829/
EDIT: Not tested wifi. USB, remote and network plugs works.Last edited by Jafarin; 20 February 2018, 12:02.
Originally posted by bugmenot2 View Post
Try changing video output from hdmi to rgb. It helped with some Sony and Phillips tvs.
thanks
Ervin
Originally posted by NayamAmarsheDid you guys try 20180125 update? It's slow as hell! It has made x96 mini unusable!
Sent from my F3116 using Tapatalk
I went back to stock firmware. Now, max temperature is around 85°C (which I believe is still very high), but I have no glitches while watching movies.
I use X96mini mostly for kodi...
trebor commented
02-21-2018, 23:59
Just check the heat sink is attached...just in case
I don`t know how to reply to a reply, so I pasted previous reply...
I checked the heatsink, it is attached and I even put some thermal paste od both sides of that blue cube which connects proc and heatsink.
This is the stupidest design of heatsink I have ever seen. There is no airflow through the box since there are holes only on bottom side. We all know that hotter air tends to go upwards but top part is sealed with motherboard and then with plastic case...
Well maybe that is the Problem
In theory that should work well just the thermal Pad (blueblock)...
I would clean the paste off,
Maybe look around for some more thermal pad
Maybe put a small heatsink on cpu with paste and use blueblock between heat sink and block
Airflow is never great on most devices like this
Also, that paste is designed specifically for transferring heat so it cannot hurt, only benefit...
Ervin
There are currently 2067 users online. 3 members and 2064 guests.
