X96 Mini TV Box Amlogic S905W + Android 7.1.2 + Quad-core Cortex-A53 + 4K VP9 H.265
    Originally posted by jiangsai0703 View Post
    yes, X96(S905x) and x96mini(S905W) are different
    whats actually different about them?
      Originally posted by erw1n View Post
      i have a problem with my Android box x96 mini. I have connected it to my Sony bravia kdl-40ex600. Often the collors goes green. I changed all the settings in the TV or android and the problem is still. Please can some one help to resolve this issue?
      thank you in advance
      Ervin
      In the Droid Config change the resolution of color to RGB 8bits o RGB 10bits. It's OK.
        Chipsets....
          Originally posted by reed View Post
          Change software with Tanix tx3 mini.
          got a link to tx3 firmware
          my wireless is hopeless on x96mini
            Would like to apply external antennas. Any way? Did not find connectors :-P
              What about pairing box' remote with TV? In my Case its a Samsung
                Not sure what you are talking about, but you can use tv remote on your tv box if you enable "hdmi cec"
                  there are two buttons on the remote one on left hand (red), another one on right hand (clear/grey). you can enter remote pairing mode by pressing the clear one for a period of time. But I could not find any information on howto pair...
                  keep pressing the clear one until it turns steady-red, now I guess its in pairing mode?
                  What bout the "set" button?
                    Remote pair
                    Hey everyone, I'm a little confused about pairing my mxq remote (default remote with a clear power button on the top right) to my tv using the buttons...
                      I used this video https://www.youtube.com/watch?v=0lOTP0RaoRU to pair my remote to tv
                        I don't understand. You have or you neen a firmware for Tanix T3 mini? If you need one google it.
                          Where is antenna pin? is it at left upper corner on Top side of PCB ???
                            You may only view thumbnails in this gallery. This gallery has 4 photos.
                              Upper left? Antenna?
                                This on has built in Antenna on PCB
                                Near chip entry point not 100% sure of exact location.
