X96 Mini TV Box Amlogic S905W + Android 7.1.2 + Quad-core Cortex-A53 + 4K VP9 H.265
    Originally posted by zzz111 View Post
    I have sent a password. Check your mail.
    Thanks bro, but it was unsuccessful. The device specs is below:
    Manufacturer HongXin
    Model x96mini
    Android version 7.1.2
    CPU 4 cores; AArch64 Processor rev 4 (aarch64) gxl; Max: 2016,0 MHz; Min: 100,0 MHz
    Display 1280 x 720; DPI: 160; Evaluated Size: 9,2"
    GPU Mali-450 MP; ARM; OpenGL ES-CM 1.1; OpenGL ES 2.0
    RAM 2048 MB (1948 MB available)
    Flash 16 GB (11.281 GB actual);
    Processor : AArch64 Processor rev 4 (aarch64)
    processor : 0
    processor : 1
    processor : 2
    processor : 3
    Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 wp half thumb fastmult vfp edsp neon vfpv3 tlsi vfpv4 idiva idivt
    CPU implementer : 0x41
    CPU architecture: 8
    CPU variant : 0x0
    CPU part : 0xd03
    CPU revision : 4
    Hardware : Amlogic
    KERNEL: Linux version 3.14.29 (ren@gxt)
    Mainboard: p212
    BRAND: Amlogic
    CPU_ABI: armeabi-v7a
    CPU_ABI2: armeabi
    DEVICE: hx_s905x
    DISPLAY: hx_s905x-userdebug 7.1.2 NHG47L 20200521 test-keys
    FINGERPRINT: Amlogic/hx_s905x/hx_s905x:7.1.2/NHG47L/20171025:userdebug/test-keys
    HARDWARE: amlogic
    TAGS: test-keys
    Whenever I try to flash roms, some soms show :
    -----------ERASE BOOTLOADER------------
    [01:40:33 530][HUB1-2][Inf]--start SendIdentifyCmd
    [01:40:33 530][HUB1-2][Inf]--2-4-0-0
    [01:40:33 531][HUB1-2][Inf]-------------Download DDR.USB-----------
    [01:40:33 531][HUB1-2][Inf]--2-4-0-0
    [01:40:33 531][HUB1-2][Inf]--Control write pll reg1 0xd9000000:0x000000b1
    [01:40:34 033][HUB1-2][Inf]--Control write pll reg1 0xd9000000:0x00005183
    [01:40:34 535][HUB1-2][Inf]--Control write pll reg1 0xd9000000:0x000000b1
    [01:40:35 036][HUB1-2][Inf]--Control write pll reg1 0xd9000000:0x00005183
    [01:40:35 536][HUB1-2][Inf]--Write initial succeed
    [01:40:35 536][HUB1-2][Inf]--Upload encrypt at 0xc8100228
    [01:40:35 536][HUB1-2][Inf]--ulValue = 0xadfc318c
    [01:40:35 536][HUB1-2][Inf]--Read encrypt value succeed
    [01:40:35 536][HUB1-2][Inf]--Download DDR.USB,size: 49152!
    [01:40:35 545][HUB1-2][Inf]--Transfer complete 49152
    [01:40:35 545][HUB1-2][Inf]--Run at address 0xd9000000
    [01:40:35 545][HUB1-2][Inf]--RunInRam success
    [01:40:35 558][HUB1-2][Inf]--2-2-0-8-0-1-0-0
    [01:40:35 558][HUB1-2][Inf]--CheckFileRunState return 8
    [01:40:35 558][HUB1-2][Inf]--Run at address 0xd900c000
    [01:40:35 558][HUB1-2][Inf]--RunInRam succeed
    [01:40:35 898][HUB1-2][Err]--ReadLargeMemCMD failed ret = -5
    [01:40:35 898][HUB1-2][Err]--ReadPara failed
    [01:40:35 902][HUB1-2][Err]--[0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error
    and some roms show:
    [01:39:02 455][HUB1-2][Inf]--------------ERASE BOOTLOADER------------
    [01:39:02 556][HUB1-2][Inf]--start SendIdentifyCmd
    [01:39:02 556][HUB1-2][Inf]--2-4-0-0
    [01:39:02 556][HUB1-2][Inf]-------------Download DDR.USB-----------
    [01:39:02 556][HUB1-2][Inf]--Control write pll reg1 0xd9000000:0x000000b1
    [01:39:03 057][HUB1-2][Inf]--Control write pll reg1 0xd9000000:0x00005183
    [01:39:03 559][HUB1-2][Inf]--Control write pll reg1 0xd9000000:0x000000b1
    [01:39:04 060][HUB1-2][Inf]--Control write pll reg1 0xd9000000:0x00005183
    [01:39:04 560][HUB1-2][Inf]--Write initial succeed
    [01:39:04 560][HUB1-2][Inf]--Upload encrypt at 0xc8100228
    [01:39:04 560][HUB1-2][Inf]--ulValue = 0xadfc318c
    [01:39:04 560][HUB1-2][Inf]--Read encrypt value succeed
    [01:39:04 560][HUB1-2][Inf]--Download DDR.USB,size: 49152!
    [01:39:04 569][HUB1-2][Inf]--Transfer complete 49152
    [01:39:04 570][HUB1-2][Inf]--Run at address 0xd9000000
    [01:39:04 570][HUB1-2][Inf]--RunInRam success
    [01:39:04 927][HUB1-2][Inf]--IOCTL_IDENTIFY_HOST_Handler ret=-5 error_msg=libusb0-dll:err [control_msg] sending control message failed, win error: A device attached to the system is not functioning.
    [01:39:04 935][HUB1-2][Err]--[0x10105004]Romcode/Initialize DDR/Read initialize status/Error result
    I know you have connections with chinease developers. Please help me regarding this.
    Once again thanks.
      Originally posted by rajibprince View Post
      zzz111 Before flashing the atvxperience I saw the information on cpu-z that I have the p212 board and cpu frequency was 2 GHz (S905X) RAM was 1948 MB and I also looked at /proc/cpuinfo and /proc/meminfo. By the way, I have joined in the channel https://t.me/Chinese_electronics . Now what to do. Please help.
      specs could be faked too!!! check hardware on PCB board
        You may only view thumbnails in this gallery. This gallery has 5 photos.
          check number of ram chip and type...then youll see
            1. ram = KINGMAX KEP08GSC-SACDTIAM3D43 (http://bbs.16rd.com/thread-59453-1-1.html) I have doubt that it is lpddr3 or not. can u check it?
            2.EMMC= kmre1000bm-b512
              U can see from the pics that its manufacturing date is 20200602 and X96_LP3_V2.0. It's very latest i think
                Hello, I need some help regarding my x96 mini box 2GB RAM 16GB ROM bought from online store, the seller said it is real 2GB RAM and 16GB ROM. I have this Q6X v2.3 18186 version pcb board with rom and ram model as seen in the pictures. Is it true this box is only 1GB ram and 8GB rom based on chip in he photos. What compatible firmware can I install on this box without bricking it? Can I install firmware from ATVxperience? Or do you guys have any information what is the recommended custom firmware for this box? Is this box has locked uboot or bootloader? Click image for larger version
                  zzz111 I have bricked my x96 mini flashing atvxperience s905x which I bought it 7days ago. But before that I tried to flash stock 7.1 and stock 9 but failed. Then I opened it and found it has s905x instead of s905w. Now I found the way to short the pin and detected the pc but fails at 2% rom code initialzation error or usb control error. On the back of the motherboard its written: X96 _LP3_V2.0_00418. I think they used the modified uboot for this device and as I bought it from local store so there is no way to contact the original seller of this device. Please help me. I allready subscribed and comment on your video. But when I open the telegram it shows that I am not a member, please help
                  I have unbricked my device flashing original stock rom from seller. Somehow I managed to find out the manufacturer name from kernel screenshot(before brick). No custom rom works with that device. Whatever I flash other then stock firmware, its bricked. Is there anyway that I can modify the stock img by amlogic customization tool with atvexperienceto make it work?
                    Please collect stock firmware from the seller or original manufacturer before flashing other roms.
