X96 Mini TV Box Amlogic S905W + Android 7.1.2 + Quad-core Cortex-A53 + 4K VP9 H.265
hi iam using x96 mini android tv box but now its power is not geeting on .No light in the front panel when the adapter is switched on.The adapter is all ok but no light in x96 mini
so i need a repair and service for my device is there any person knows how to make my device working. i think it needs a chip level checking.expecting ur response ASAP thank you
Hello!
I have a X96 Mini the Board version is Q6x v2.2 17355. Unfortunately, it is bricked while installing another firmware and now the LED is red. I tried several firmware even follow the https://blog.danman.eu/bricking-and-...ntar-x96-mini/ and short the pins but not get blue light.
The Burning tool detect the device p281 but failed to flash firmware with following error
[0x10103005]Romcode/Initialize DDR/Download buffer/Read item data failed
I search the forums and found that this error was due to a wrong firmware flashing. But I have tired many firmware for the X96 Mini S905W chipset, but not able to unbrick it so far.
If you have any suggestion please let me know or share the firmware that I can use to fix it.
ThanksYou may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
your device is not bricked. try to flash from another PC with this method: start the USB burning tools, load the rom img ,push start, insert a matchstick into av hole until you feel a click, hold there and insert the usb cable . process will start and with some luck wiil go on. if not , change the cable and computer. Personnaly I need to flash from an old computer because my last state of art pc always give error!
Originally posted by NayamAmarshe
The new board uses a different ddr and uboot.
That's why other firmwares are not working which is a big problem. I need the original firmware for new x96 mini to be able to push a patch
I have a bricked new X96 mini that tried to flash with your wicked rom using the sd card method, just red light now.
I also have the same box vanilla, can I extract the files you need from the good box?
There are currently 3117 users online. 1 members and 3116 guests.
