X96 Mini TV Box Amlogic S905W + Android 7.1.2 + Quad-core Cortex-A53 + 4K VP9 H.265
@Jami, Stop wasting your time unless you find the firmware from the original supplier of your H/W of X96 mini, i have tried on three different models of X96mini form different factories with Same PCB Board Printed Q6X V2.2 17355 and all with Samsung ROM, but not a single firmware available over net or on ChinaGadget working on any of the three boxes i have, all the chinese manufacturer of X96mini are now producing their Boxes with secured Boot with the firmware. so it will only work with their hardware only & will not work universally on any X96mini, So wait till someone hacks their Bootloader.Last edited by tiku; 21 December 2018, 15:52.
Hi. Greetings from Spain. Hope you can help me. I have a problem with my X96 mini remote. The Stop buttom doesn't work properly, works like Play/Pause buttom. This is the original remote.conf:
Code:#************************************************* ************************************************** ****** #this file is configuration for each factory remote device # work_mode 0 :software mode 1 :hardware mode # repeat_enable 0 :disable repeat 1 :enable repeat # # factory_code each device has it's unique factory code. # pattern:custom_code(16bit)+index_code(16bit) # examble: 0xff000001 = 0xff00(custom cod) 0001 (index) # # release_delay unit:ms.release will report from kernel to user layer after this period of time # from press or repeat triggered. # # debug_enable 0 :debug disable 1 :debug disable # # SW MODE: # bit_count how many bits in each frame # tw_leader_act time window for leader active # tw_bit0 time window for bit0 time. # tw_bit1 time window for bit1 time # tw_repeat_leader time window for repeat leader # REG # reg_base_gen set value for PREG_IR_DEC_BASE_GEN # reg_control set value for PREG_IR_DEC_CONTROL # reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE # reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE # reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE # reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME #************************************************* ************************************************** ********** #amlogic NEC remote work_mode = 0 repeat_enable = 1 repeat_delay = 130 repeat_peroid = 120 release_delay = 20 debug_enable = 1 fn_key_scancode = 0x00 left_key_scancode = 0x51 right_key_scancode = 0x50 up_key_scancode = 0x16 down_key_scancode = 0x1a ok_key_scancode = 0x13 #pageup_key_scancode = 0x04 #pagedown_key_scancode = 0x1b custom_begin factory_infcode = 0 factory_code = 0xfe010001 mouse_begin 0 0x51 //mouse key left 1 0x50 //mouse key right 2 0x16 //mouse key up 3 0x1a //mouse key down mouse_end key_begin 0x11 102 #HOME 0x19 158 #EXIT 0x4c 125 #MENU 0x40 116 #ON/OFF 0x18 115 #VOL+ 0x10 114 #VOL- 0x16 103 #UP 0x51 105 #LEFT 0x13 97 #DPAD_CENTER 0x50 106 #RIGHT 0x1a 108 #DOWN 0x41 113 #MUTE 0x5a 119 #PLAY_PAUSE 0x52 124 #MEDIA_PAUSE 0x0a 257 #MUSIC # 0x49 261 #PICTURE PLAYER 0x4d 263 #SHORTCUT_VIDEOPLAYER # 0x48 262 #SHORTCUT_FILEBROWSER 0x03 217 #SEARCH 0x0e 70 #267->WEBSITE #70-->EXPLORE 0x43 255 #SETTINGS 0x54 120 #FAST_FORWARD 0x55 121 #REWIND 0x59 122 #PREV 0x58 123 #NEXT 0x4e 2 #1 0x0d 3 #2 0x0c 4 #3 0x4a 5 #4 0x09 6 #5 0x08 7 #6 0x46 8 #7 0x05 9 #8 0x04 10 #9 0x01 11 #0 0x42 14 #DEL # 0x52 128 #MEDIA_STOP # 0x45 264 #ONEKEY_ZOOM 0x06 265 #SHORTCUT_SUBTITLE 0x44 266 #KODI 0x0f 233 #MAIN_MENU # 0x12 269 # F9 0x47 112 #@ AT 0x0a 111 #MUSIC 0x4d 101 # (F3)VIDEO 0x49 66 #(F1)PHOTO 0x48 77 #(F2)FILE 0x12 88 #(F9)CLEAN 0xf2 140 #F10 oritation 0x4b 140 #F10 oritation 0x45 99 #(F6)ZOOM key_end repeat_key_begin 0x11 102 #HOME 0x19 158 #EXIT 0x4c 125 #MENU 0x40 116 #ON/OFF 0x18 115 #VOL+ 0x10 114 #VOL- 0x16 103 #UP 0x51 105 #LEFT 0x13 97 #DPAD_CENTER 0x50 106 #RIGHT 0x1a 108 #DOWN 0x41 113 #MUTE 0x5a 119 #PLAY_PAUSE 0x52 124 #MEDIA_PAUSE 0x0a 257 #MUSIC # 0x49 261 #PICTURE PLAYER 0x4d 263 #SHORTCUT_VIDEOPLAYER # 0x48 262 #SHORTCUT_FILEBROWSER 0x03 217 #SEARCH 0x0e 70 #267->WEBSITE #70-->EXPLORE 0x43 255 #SETTINGS 0x54 120 #FAST_FORWARD 0x55 121 #REWIND 0x59 122 #PREV 0x58 123 #NEXT 0x4e 2 #1 0x0d 3 #2 0x0c 4 #3 0x4a 5 #4 0x09 6 #5 0x08 7 #6 0x46 8 #7 0x05 9 #8 0x04 10 #9 0x01 11 #0 0x42 14 #DEL # 0x52 128 #MEDIA_STOP # 0x45 264 #ONEKEY_ZOOM 0x06 265 #SHORTCUT_SUBTITLE 0x44 266 #KODI 0x0f 233 #MAIN_MENU # 0x12 269 # F9 0x47 112 #@ AT 0x0a 111 #MUSIC 0x4d 101 # (F3)VIDEO 0x49 66 #(F1)PHOTO 0x48 77 #(F2)FILE 0x12 88 #(F9)CLEAN 0xf2 140 #F10 oritation 0x4b 140 #F10 oritation 0x45 99 #(F6)ZOOM repeat_key_end custom_end custom_begin factory_infcode = 1 factory_code = 0xbd020001 key_begin 0xca 103 0xd2 108 0x99 105 0xc1 106 0xce 97 0x45 116 0xc5 133 0x80 113 0xd0 15 0xd6 125 0x95 102 0xdd 104 0x8c 109 0x89 131 0x9c 130 0x9a 120 0xcd 121 key_end custom_end
Code:#************************************************* ************************************************** ****** #this file is configuration for each factory remote device # work_mode 0 :software mode 1 :hardware mode # repeat_enable 0 :disable repeat 1 :enable repeat # # factory_code each device has it's unique factory code. # pattern:custom_code(16bit)+index_code(16bit) # examble: 0xff000001 = 0xff00(custom cod) 0001 (index) # # release_delay unit:ms.release will report from kernel to user layer after this period of time # from press or repeat triggered. # # debug_enable 0 :debug disable 1 :debug disable # # SW MODE: # bit_count how many bits in each frame # tw_leader_act time window for leader active # tw_bit0 time window for bit0 time. # tw_bit1 time window for bit1 time # tw_repeat_leader time window for repeat leader # REG # reg_base_gen set value for PREG_IR_DEC_BASE_GEN # reg_control set value for PREG_IR_DEC_CONTROL # reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE # reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE # reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE # reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME #************************************************* ************************************************** ********** #amlogic NEC remote work_mode = 0 repeat_enable = 1 repeat_delay = 130 repeat_peroid = 120 release_delay = 20 debug_enable = 1 fn_key_scancode = 0x00 left_key_scancode = 0x51 right_key_scancode = 0x50 up_key_scancode = 0x16 down_key_scancode = 0x1a ok_key_scancode = 0x13 #pageup_key_scancode = 0x04 #pagedown_key_scancode = 0x1b custom_begin factory_infcode = 0 factory_code = 0xfe010001 mouse_begin 0 0x51 //mouse key left 1 0x50 //mouse key right 2 0x16 //mouse key up 3 0x1a //mouse key down mouse_end key_begin 0x11 102 #HOME 0x19 158 #EXIT 0x4c 125 #MENU 0x40 116 #ON/OFF 0x18 115 #VOL+ 0x10 114 #VOL- 0x16 103 #UP 0x51 105 #LEFT 0x13 97 #DPAD_CENTER 0x50 106 #RIGHT 0x1a 108 #DOWN 0x41 113 #MUTE 0x5a 119 #PLAY_PAUSE 0x52 128 #MEDIA_STOP 0x0a 257 #MUSIC # 0x49 261 #PICTURE PLAYER 0x4d 263 #SHORTCUT_VIDEOPLAYER # 0x48 262 #SHORTCUT_FILEBROWSER 0x03 217 #SEARCH 0x0e 70 #267->WEBSITE #70-->EXPLORE 0x43 255 #SETTINGS 0x54 120 #FAST_FORWARD 0x55 121 #REWIND 0x59 122 #PREV 0x58 123 #NEXT 0x4e 2 #1 0x0d 3 #2 0x0c 4 #3 0x4a 5 #4 0x09 6 #5 0x08 7 #6 0x46 8 #7 0x05 9 #8 0x04 10 #9 0x01 11 #0 0x42 14 #DEL # 0x45 264 #ONEKEY_ZOOM 0x06 265 #SHORTCUT_SUBTITLE 0x44 266 #KODI 0x0f 233 #MAIN_MENU # 0x12 269 # F9 0x47 112 #@ AT 0x0a 111 #MUSIC 0x4d 101 # (F3)VIDEO 0x49 66 #(F1)PHOTO 0x48 77 #(F2)FILE 0x12 88 #(F9)CLEAN 0xf2 140 #F10 oritation 0x4b 140 #F10 oritation 0x45 99 #(F6)ZOOM key_end custom_end
i also had this device which is dead now after flashing incompatible atvxperience.. 1gb ram (showed up 2gb in CPU Z), s905w processor with p282 board.. anyone here have stock firmware for my device? has been trying bunch of fw on the net with no luck (stuck at 7% DiskInitial Error). thanks.You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoLast edited by netrix; 22 December 2018, 09:57.
Originally posted by Sun_Storm View PostI received yesterday a X96 mini 2Gb with board v2.3
I will try to install TWRP and make a backup. If done I will upload it. After that I will flash Atvxperience v2ff with usb burning tool and report sucess or fail.
Unable to lunch TWRP with native rom, the recovery.img (twrp.p212-3.1.1-0-signed) not visible in SD card into native recovery. But no issue for flashing Atvxperience V2FF with USB Burning tool (boad PCB v2.3)Last edited by Sun_Storm; 09 January 2019, 14:54.
tiku I have an X96 mini 4k Amlogic S905W 2GB 16GB. I bricked my box after supposedly successfully flashing a firmware from Atv experience. I have a solid red light. I've tried flashing a number of firmwares without success via sd card and Amlogic tool. The tool always shows a connection but I get that 1% with ]--[0x10103005]Romcode/Initialize DDR/Download buffer/Read item data failed error Jami mentioned in an earlier post. The vendor gave me a link to the (supposedly) stock firmware but I can't flash that either. When unzipped the file says mxq-4k-6051-nv2-1114. Of course, the ?mxq? makes me wonder if it?s even the correct firmware. I wrote to the company in China a week ago but no reply yet. Is the locked bootloader business you mention likely the reason I can?t flash it? I do have access to an identical box but the way people write instructions on copying a ROM are confusing to say the least, and one poster said you could easily brick the good box by trying. Would you advise trying to copy the ROM from the good box and flashing it to the brick? If so, can you recommend a good tutorial? Thanks in advance!
Hi again. Sorry for not being more clear. I have two boxes. What I'm wondering is if there is a way to copy the ROM from the working box (even if the box is fake) and load it onto the bricked box. I've read that you can brick a box trying to copy the ROM and would like to know if you have a preferred way of doing this so as to avoid bricking the good box while trying to copy its ROM.)
Originally posted by Quinte View PostHi again. Sorry for not being more clear. I have two boxes. What I'm wondering is if there is a way to copy the ROM from the working box (even if the box is fake) and load it onto the bricked box. I've read that you can brick a box trying to copy the ROM and would like to know if you have a preferred way of doing this so as to avoid bricking the good box while trying to copy its ROM.)
There are currently 3514 users online. 0 members and 3514 guests.
