[ROM] Yundoo Y8 Android 7.1.2 - SCV1
Hi Superceleron. Thank you for your 7.1.2 SCV1 ROM, resolved a lot of the picture and sound issues I had with the original H96 Max firmware. However I noticed I'm only getting stereo output out of SPDIF when using FTMC ... is that a ROM firmware issue or a FTMC issue? I tried all different sound combinations and permutations from OS system sound settings and FTMC system audio settings but best outcome is only stereo out on PCM.
Originally posted by LeKodeur View PostHi Superceleron. Thank you for your 7.1.2 SCV1 ROM, resolved a lot of the picture and sound issues I had with the original H96 Max firmware. However I noticed I'm only getting stereo output out of SPDIF when using FTMC ... is that a ROM firmware issue or a FTMC issue? I tried all different sound combinations and permutations from OS system sound settings and FTMC system audio settings but best outcome is only stereo out on PCM.
superceleron do you have the original launcher apk for the yundoo y8. reason i'n not a fan of the WeOS launcher. so i downgraded back to 6.01 because i like the original launcher. basically i gave up performance for simplicity lol. thanks for all the hard work.
I’m not that verse in those kinda stuff lol. Is there anyway you would be able to do this for us so we get the option to use the original launcher instead of weos?
that would be very thankful if you would.
superceleron still if you can’t no worries I still appreciate your hard work and efforts and continue to keep up the good work in improving the yundoo y8
I have following problems after installation 7.1.2:
1. There is no AFR in the FTMC;
2. I can not go to the physical keyboard from the English keyboard layout to Russian and vice versa;
3. Do not save widgets after reboot;
4. There is no way to destroy all open applications in the navigation bar (as it was in beta 6).
superceleron thanks for your great work, I successfully install the android 7.1.2 scv1, but the box become boot loop at logo. I tried several time install the firmware. but still same result boot loop. I downgrade to android 6 scv1. How to solve this issue?..
Originally posted by zulengineer View Postsuperceleron thanks for your great work, I successfully install the android 7.1.2 scv1, but the box become boot loop at logo. I tried several time install the firmware. but still same result boot loop. I downgrade to android 6 scv1. How to solve this issue?..
At me such too it is observed, if in a port usb 3.1 C there is a flash card during reboot. I made the firmware through the computer, the full image.
And further. It is not possible to set the frequencies 24, 25, 30 Hz manually in the TV mode. But only 60, 50 Hz are set. Maybe that's why there's no AFR ?
There are currently 2282 users online. 0 members and 2282 guests.
