Many Thks to my beta tester trebor
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
Changelog V1:
- Based on stock
- Added ATV screensaver ( Default 5 min. )
- General optimization, should be smoother and faster!
- Fixed screen orientation.
- Some house clean!
- Mem usage lot better now.
- Boot a lot faster, emmc also faster!
- Youtube 4K support ( using youtube atv app version 2 )
- Fixed search crash in youtube atv app.
- Double press or long press in Home button brings app kill/switch menu.
- Fixed settings actionbar.
- A more ATV feel.
- Added the Navigation Bar
- Added Status/Navigation bar auto hide, so don't show anymore on Youtube and other apps!
- Added a setup wizard.
- Organized some boot scripts.
- Added lots of kl's.
- Netflix, youtube, playstore...etc... fully working.
- Many Gamepads supported.
- Gapps updated
- Lots Permissions fixed.
- FTMC Build 31 RKversion ( The best player for this device, dont forget to enable all RKCodec options in "system" )
- Fixed RKcodec Playback and fractional HDMI in FTMC. (Fractional HDMI Only works in the 3328 and 3399)
- Added a few apps...
- Updated some codecs
- Added SC modded WeOS launcher ( Menu button on the remote is your friend in this launcher )
- And a lot of other under the hood changes.
Bugs V1:
- Don't try Magisk, it wont work!
- The rom is rooted with supersu 2.82 BUT NO supersu app due to some Incompatibilities, and if you add it DONT UPDATE SU BINARY YOU WILL GET A BOOT LOOP!
- I bet a lot more Bugs...
Want to buy me a beer?
Download:
- DOWNLOAD HERE SCV1 for Yundoo Y8
- MD5: 334DA86F9ABA3DC932F419AB5A36A154
Install instructions:
- Search the forum for instructions, is the same as all other rk boxes...
- This box if you want to use a external USB HDD powered by the box you need at least a 3Amps PSU.
Where to buy:
1ยบ BOOT MAY TAKE AROUND 5 MINUTES MAYBE LESS!
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
