[ROM] Yundoo Y8 Android 7.1.2 - SCV1
Originally posted by superceleron View Postmaybe in the next version i will try to add it!
time is passing by so fast and I just wanted to know if you're still active in this forum. I've read your messages that your work is really demanding and you're tired of updating all these devices. Does that mean that your passion for developing these tv-boxes is gone forever? Will there ever be an update to Android Oreo on any of these devices (...i've heard something about the xiaomi mi box)?
Well, i wish you all the best for your private life and hope that we will hear from you again - even then if it's not Yundoo Y8 related.
Best wishes
Dukekox
Hi guys,
I try to flash my Yundoo Y8 with the 7.1.2 SCV1 ROM but i cannot get the device to be connected with my computer.
I created the USB Type-A Male to A Male cable from the following thread:
http://freaktab.com/forum/tv-player-...lashing-tv-box
I put the one side to the blue USB (USB 3.0) on my Yundoo device and before that i have pressed and kept the reset switch inside the "R" plug. I did that without power supply and with power supply BUT nothing happens. I had installed the RK drivers 4.5 and i have opened the AT 2.3.9 window but the only message i see is "No Device Found" at the AT2.3.9 window and at Device Manager window under USB tab i do not see any new device to connect...
What am I doing wrong? Which port is the OTG port? The Blue USB3.0 Type-A Male or Type-C next to Blue Type-A?
Thank you for your help!!!!!!!!!!!!!Last edited by kinglyr; 01 October 2018, 09:02.
Originally posted by superceleron View PostHi guys/girls, sorry for the lack of updates, but really dont have to much free time this days to do my custom rom work, if anything changes i will update my roms if not...
what Wifichip does the Y8 use , is it the same as X99 , AP6255 ???
wanna test it on my X99 ,
greetings / gefattern
Originally posted by trebor View PostPictures here
http://freaktab.com/forum/tv-player-...055#post637055
thanks for Info , forgot about the Pictures , Y8 use a AP6356S , not nice for me now , maybe it works if i flash
the recource & kernel.img of the X99 afterwards , like this was done on RK3188 & RK3288 to fix Wifi Problems ,
hope so , greetings / gefattern
superceleron, thank you again so much for being able to give a new life to this box. I'm using your ROMs since the A6 and this A7 since it came out. As we all know, while this ROM is awesome and fixed so many bugs from the original ones, but as it was already reported, it still requires some polishing. I would really be so grateful to you if it would be possible to fix:- USB bug - if I restart the box, I need to remove the USB transmitter of the air mouse and restart again;
- Can't use my external HDD (3TB, USB3.0). I've bought a 4A PSU, and it still can't detect it. With your A6 ROM, it worked perfectly.
- Sometimes the box stop sending the sound to the TV. Haven't found a way to reproduce the error as it happens like once per 3 weeks. Need to reboot the box and start again.
- It would be a "nice to have" if we could have the SuperSu from the install; if not, some posts back another user already gave a possible solution for us...
I know that you're full of work and this is free labour, but please, don't forget us... nobody else is able to fix this for us... Again, even if you're able to get the time to solve this, THANK YOU so much for your work until now!!
don't understand the hdd thing I use an 8tb external hdd with usb2 or 3 no problems except the the time it takes to be detected it seems to take a minute or 2 to be detected with media app and x player don't detect it at all but then xplayer seems very picky about the the hard drives it will detect
Originally posted by trinidad View Postdon't understand the hdd thing I use an 8tb external hdd with usb2 or 3 no problems except the the time it takes to be detected it seems to take a minute or 2 to be detected with media app and x player don't detect it at all but then xplayer seems very picky about the the hard drives it will detect
dunno how lucky I am depends how many people are having problems .but I like I said the player built into the rom seems to work best ..media centre... it detects my internal and external sd cards and my pc ,and if I turn on my hdd wait a couple of minutes and then scroll up or down its detected that as well I also have 1tb and 2tb hdd and if I plug them in they are also detected just faster .cannot understand why yours don't work
Originally posted by trinidad View Postdunno how lucky I am depends how many people are having problems .but I like I said the player built into the rom seems to work best ..media centre... it detects my internal and external sd cards and my pc ,and if I turn on my hdd wait a couple of minutes and then scroll up or down its detected that as well I also have 1tb and 2tb hdd and if I plug them in they are also detected just faster .cannot understand why yours don't work
There are currently 1627 users online. 3 members and 1624 guests.
