[ROM] Yundoo Y8 Android 7.1.2 - SCV1
Originally posted by ADD View PostFor those having HDD problem with A7, you need to either use a 3A power adapter or grab an external power for your HDD. Get yourselves a Y cable for HDD. This will resolve the issue.
Good luck
the player see the hard drive on startup...
Otherwise it did not work for me either...
I am using a 3 amp power supply ...
Good Luck
Michael T.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
HI, I successful flash my yunddo with Yundoo_Y8_SCV1-7.1.2.img.
Now, I try to install DRM Wideline level 3. (Its just software level).
(level 1=impossible= is hardware process the compagny(yundoo) have to do). https://www.androidauthority.com/wid...lained-821935/
Anyone find a way to install it ?? or with another Rom ?...
Netflix works but on my country there some apps require DRM....
Originally posted by bergamesk View Postand for the N6 MAX??
might be I'll try though
superceleron Wow! Sure would be a blessing to the Magicsee N6.
... It is shipped with very amateur FW.
Maybe I should forward your work as an example of what a quality, thoughtful, and well written rom looks and operates, Real and useful features.
Shortcuts and copying is a benchmark in the land of the great wall... Why not, at least, attempt to imitate The Best.?Kris....don't forget my boxes! Okay?
Originally posted by ClarkKent View Post
+1
did u flash the Rom to your N6 & it works well , is this correct ???
greetings / gefattern
No I didn't. Mine is still a couple of days from arrival. I was hoping at Berg was going to give it a try.
Everybody needs a good test case?
At this point, I'm not sure I'll even open the package.
Much frustration, and the likelihood of a brick while trying to fix ... Is not what I hoped to buy.
IT may be back to amlogic for me.
... But I want a faster soc than the 905x.x with 3.0+ usb support.
Why this is not available for s912 IDK ?!Kris....don't forget my boxes! Okay?
Originally posted by ClarkKent View PostNo I didn't. Mine is still a couple of days from arrival. I was hoping at Berg was going to give it a try.
hope all comes good , good luck / gefattern
Guy i can't Believe it...OMG.. Its Workings...I find a way for the DRM level 3..... I need some confirmation... if someone can try.
I brick my yundoo...I re-install the 7.1.2 image rom... re-isntall Su-free and Es-explorer .....
I compare all DRM file in /system/vendor/lib and one file is very different. (with the Rom file: H96 max rk3399 7.1 180102 --> i extract all files)
/system/vendor/lib/mediadrm/libwvdrmengine.so ( 1 532 728 Bytes) I replace this file and it works !!!!, see DRM info.
I link the file ins this post. https://mega.nz/#!o49TgSRC!6sxcOnzXe...Pljr-Qvr_4DIYU
There are currently 1582 users online. 0 members and 1582 guests.
