But now, OrangeTV, Canalplus , RmC sport , Molotov TV, amazon.... works now for my country !!
[ROM] Yundoo Y8 Android 7.1.2 - SCV1
Originally posted by superceleron View Postyes i forgot to add that in scv1... that is why i was doing a scv2, i did a beta with that fixed but them... life/work took over
so you are busy with a SCV2 Version for Y8 , or do i understand something wrong ,
greetings / gefattern
Originally posted by Stratanic View PostGuy i can't Believe it...OMG.. Its Workings...I find a way for the DRM level 3..... I need some confirmation... if someone can try.
I brick my yundoo...I re-install the 7.1.2 image rom... re-isntall Su-free and Es-explorer .....
I compare all DRM file in /system/vendor/lib and one file is very different. (with the Rom file: H96 max rk3399 7.1 180102 --> i extract all files)
/system/vendor/lib/mediadrm/libwvdrmengine.so ( 1 532 728 Bytes) I replace this file and it works !!!!, see DRM info.
I link the file ins this post. https://mega.nz/#!o49TgSRC!6sxcOnzXe...Pljr-Qvr_4DIYU
Awesome!!
I was stuck on this device bcz of DRM L3 requirement for some apps. I wasn't able to run these apps.
But now,with the file you provided,device is DRM L3!!!
Thank you very much. I didnt delete anything in this folder only copy pasted the provided file.Gave permission 644.Rebooted.
Thank you very much again
There are currently 2376 users online. 0 members and 2376 guests.
