[ROM] Yundoo Y8 Android 7.1.2 - SCV1
Updated manual https://github.com/big-town/usbreser...ster/README.md. We found a solution with autostart.
Originally posted by big-town View PostUpdated manual https://github.com/big-town/usbreser...ster/README.md. We found a solution with autostart.
can you post a link to download the bin you compiled ...and the scripts maybe a zip or rar file would be great ..
Thanks in advance
I do not have a compiler or your skills...
Michael T.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
Originally posted by michael2t View Post
hello big-town
Thanks in advance
Michael T.
Hello big-town
thank you ... thank you ....thank you ... please
(((SMILES)))
By the way, can someone tell me if there is a way to make this box autostarting on plugging in? Because I still need to push the power botton on the device to start.
Guest
Hi all. Will this rom work good with a H96 Max rk 3399 rockchip android tv box ? Did anyone tried? I Already tried Superceleron's 7.1.2. Scv1 beta custom rom but i have the wifi problem not turning itself on and i understand it's a wifichip compatibility issue. Looking forward for some answers. Cheers ! ☺
Originally posted by Mr_Odd View PostHi all. Will this rom work good with a H96 Max rk 3399 rockchip android tv box ? Did anyone tried? I Already tried Superceleron's 7.1.2. Scv1 beta custom rom but i have the wifi problem not turning itself on and i understand it's a wifichip compatibility issue. Looking forward for some answers. Cheers ! ☺
u can try , but as Superceleron already answer before , No , shall not work , u can try to extract "recource & kernel.img"
of your Stockrom and flash afterward over the SVC1 , maybe , maybe this helps with Wifi ???
good luck / gefattern
Guest
Hi ,
Firstly i would like to congratulate #Superceleron for this great modded rom, it runs awesome. I bought this box, just after it launched and your roms, both marshmallow and nougat versions, gave a new life to it. I would just like to comment somethings i accidentally found on this rom, so it goes. I successfully updated su with supersu with no bootloop, just install supersu as system app before reboot. I managed to successfully run and test with some packages twrp, just pick the twrp of rk3328 device on this page http://freaktab.com/forum/tv-player-...ckchip-devices, decompress it and change its fstab mountpoints to correspond to our devices rom parameter file (only bug is twrp's just half screen size). I found one annoying bug on nougat rom, i cant pair sbs bluetooth gamepad, just restarst bluetooh every time, it works great on your marshmallow rom.
Originally posted by s1l View PostFirstly i would like to congratulate #Superceleron for this great modded rom, it runs awesome. I bought this box, just after it launched and your roms, both marshmallow and nougat versions, gave a new life to it. I would just like to comment somethings i accidentally found on this rom, so it goes. I successfully updated su with supersu with no bootloop, just install supersu as system app before reboot. I managed to successfully run and test with some packages twrp, just pick the twrp of rk3328 device on this page http://freaktab.com/forum/tv-player-...ckchip-devices, decompress it and change its fstab mountpoints to correspond to our devices rom parameter file (only bug is twrp's just half screen size). I found one annoying bug on nougat rom, i cant pair sbs bluetooth gamepad, just restarst bluetooh every time, it works great on your marshmallow rom.
Originally posted by s1l View Posthttp://freaktab.com/forum/tv-player-...ckchip-devices, decompress it and change its fstab mountpoints to correspond to our devices rom parameter file (only bug is twrp's just half screen size).
thank you!
Originally posted by JoseM View Post
did you update su binaries ? or just installed supersu as system app
Originally posted by isaauco View Post
can you tell how you decompressed and what is the final look of the fstab that you edited? also... how to compress it back to img in order to flash it to the recovery partition?
thank you!
There are currently 2186 users online. 1 members and 2185 guests.
