LightHome Launcher With New Look and Optimized
Originally posted by teutate View Post
To change the links is it enough if I edit the values in res>values>strings.xml or are there other files to fix?
Only thing not working is the poweroff button in the lower left corner.
Any fix?
Originally posted by ahac85 View PostI have one box with android 6 on it and I'll take a look at what options i get when the settings button is clicked and see if theres a workaround.
Edit: My android 6 box when clicking on settings button takes you to the black settings menu, then in there, there is a button called more settings when clicked launches the white settings menu.
Hello friends.
I have a H96 MAX X2 (S905X2). You have a cool launcher. but on my console it doesn't work correctly. Does not start ES File Manager. Neither Pro nor Free version. Tested on different firmware. Your launcher downloaded from this message. Tested with KODI button.
Or tell me what to do to make File Manager work.Last edited by Rex72; 04-11-2019, 08:49.
It's strange i have tested and button works fine with es file explorer manager. Send me a PM to upload for you a premium version to test and a modified folder if you want.Last edited by Talaki; 04-13-2019, 14:26.
Originally posted by ahac85 View PostThese are all the builds I've put together. These versions include the latest weatherfix by Beelink just make sure you either have gps toggle off or deny location permission to the launcher so that it doesn't crash (Beelinks fault, not mine). YouTube versions now includes the bigger font button. Enjoy
Kodi Button + Launch ES File Explorer Free Version + Google Chrome
https://mega.nz/#!9ZggiATJ!bpEgZHGqP...cet_Wa83GwJaaw
Kodi Button + Launch ES File Explorer Pro Version + Google Chrome
https://mega.nz/#!ZJ5SjIKD!J4HvNj5sG...QEjzlKtB5pQNQ8
YouTube Button + Launch ES File Explorer Free Version + Google Chrome
https://mega.nz/#!oFg0kawB!ESoghwC8q...ydYliEk0DTAauo
YouTube TV Button + Launch ES File Explorer Free Version + Google Chrome
https://mega.nz/#!NdhChYbA!SCW_bhKoF...cT8RgyaUn-ZDTc
YouTube TV for Android can be found at
https://www.apkmirror.com/apk/google...tv-android-tv/
Originally posted by Chill007 View Post
Links don't work. Can you please update links or if someone else have some of this launchers downloaded can you upload it somewhere and add the link. Thank you!
the Es File Explorer is no longer available on PlayStore , because the Company manipulated there Apps to get more
Ad clicks and earn more Money , or similar , all Apps from them , DO ..... Company , better to use another one ,
greetings / gefattern
Hi ,
Thank you very much.
There are currently 2965 users online. 4 members and 2961 guests.
