LightHome Launcher With New Look and Optimized
Originally posted by soldiaz View PostSince I like your background and the widgets in left corner, may I ask for your upload. I just finished the icons and would like to release an IPTV launcher containing Mobdro, zattoo, iptv extreme and burning series..maybe freeflix
Originally posted by jerry98vert View PostKrypton you deserve some funds for doing this. I guess I have been out of it and didn't even see this post. I am a bit confused here due to 8 plus pages. So the first post the OP is that the current updated files?
LightHome Launcher K1-271217 - (is this for most tv boxes and it's an install apk file) and for Beelink boxes you just replace the original apk file to this file and has a Kodi button?
LightHome Launcher for Beelink GT1 Ultimate - (this is only for the Ulitimate Beelink box) all you do is replace the apk file with this one or uninstall LightHome and reinstall with this download and has Kodi button?
I think Krypton did such a great job, lighthome launcher didn't get enough love and now this.
Originally posted by soldiaz View PostThanks!
MAy I ask why it is 9megs? Old one was bout 3,5megsLast edited by ajape; 20 August 2018, 23:46.
Originally posted by jerry98vert View PostAnybody know these answers???? Thanks
I have the Beelink Mini MXIII-II which has the S905X chip in it. I have downloaded and installed your Lighthome Launcher k1-271217 as well as the Test Build: Lighthome Launcher for Beelink GT1 Ultimate. Both of these modified launchers work on the Mini MXIII-II. The KODI button launches KODI, The Files button launches the stock Beelink file manager. The Browser button launches the Chrome browser. All great with one big exception. The Box cannot be powered off by the power button in the navigation bar, nor by using the power button on the Beelink remote. When I hit the power button (using either method) the three circles come up labeled "Shutdown", "Sleep" and "Reboot". If I select either "Shutdown" or "Reboot" a message comes up saying "Lighhome has stopped working". The screen then quickly resets and is back on the Lighthome launcher. The only way to turn the box off is to pull the plug. Any suggestions? Thanks in advance/
Originally posted by futureace View PostI have the Beelink Mini MXIII-II which has the S905X chip in it. I have downloaded and installed your Lighthome Launcher k1-271217 as well as the Test Build: Lighthome Launcher for Beelink GT1 Ultimate. Both of these modified launchers work on the Mini MXIII-II. The KODI button launches KODI, The Files button launches the stock Beelink file manager. The Browser button launches the Chrome browser. All great with one big exception. The Box cannot be powered off by the power button in the navigation bar, nor by using the power button on the Beelink remote. When I hit the power button (using either method) the three circles come up labeled "Shutdown", "Sleep" and "Reboot". If I select either "Shutdown" or "Reboot" a message comes up saying "Lighhome has stopped working". The screen then quickly resets and is back on the Lighthome launcher. The only way to turn the box off is to pull the plug. Any suggestions? Thanks in advance/
If you want the latest version with the final graphic modifications and pointing to the free Root Browser Classic as the default file manager instead of the Beelink File Manager that does not access the root directory, you can find it a few posts above this one (post #122) on this same page. Enjoy!Last edited by ajape; 21 August 2018, 10:01.
@ajape: thanks for your guidance! I found out my mistake. I never signed an apk before. It is just easy, when you decompile the apk, rebuild it and then sign, you not have to clone!
My modified IPTV launcher is finished but I cannot launche Retroarch since I do not know the package name! Can someone help out? com.retroarch does not work!
Originally posted by soldiaz View Post@ajape: thanks for your guidance! I found out my mistake. I never signed an apk before. It is just easy, when you decompile the apk, rebuild it and then sign, you not have to clone!
NOTE: There's no space in the middle of the word Future, I don't know why the forum is forcing that space but it doesn't even let me correct it, so maike sure if you copy/paste to make sure you take out that additional space in "F uture" ok?
As for the signing of the APK, for me the apk I end up with would always fail on install even after signing it, with Android either telling me that there was a conflict with another app by the same name or that the package was corrupt, either way it just wouldn't work for me without cloning it at the end. But I'm gald you found a way to make your apk work directly without cloning, it means that you can make your launcher version about 2MB smaller in file size than mine ends up being always because of the cloning. It's probably because you use a better compiler than I do, but then again Easy APK Tool is as far as my skills can handle I'm afraid, so I'm stuck with it hehehe
Originally posted by soldiaz View Postmmh, what I found out is that you cannot just delete a file or wallpaper. You must leave them in apk package BUT you can decrease size by sizing them to just 1 px :-P
Hi peeps, I installed this on my H96 Pro+ and works great except the browser.
Now every time I turn on the box, it pops up the prompt to use Lighthome or the Mediabox launcher, I selected LH "always" but every time I turn the box off and on it happens again. Anyone know how I can set it so it launches the Lighthome always? Also how can I change the browser?
Cheers and thanks for your work
There are currently 2012 users online. 1 members and 2011 guests.
