LightHome Launcher With New Look and Optimized
Originally posted by castravete View Posthello. nice work! but it seems that the beelink lighthome launcher that you modified it does not work well on the beelink gt1 ultimate
(the power controlls from the remote are crashing the launcher on the latest beelink 7.1.2 firmware) the original lighthome launcher 1.1.2 is working perfect
thank's and keep up the good work
i'll wait for the fixed version to install it on my gt1 ultimate.
Recompiled test build for Beelink GT1 Ultimate. confirm if it fix the problem. Download here-RK3368 CSA91/R8/R68 V2, V4
Latest Updated Firmware for CSA91 based on Zidoo Full/Lite (Working Hardware Clock) by krypton
Originally posted by Shonk View Postany chance of patching the stock h96 pro+ launcher back to kodi instead of netflix the images are already in the apk
https://mega.nz/#!suZXlZQS!uGcrd1Voh...4viXxJLIWYhIlM
Hey dude you want this one ?
actually source also need to be changed to point to kodi instead of netflex let me check if i can manage to reverse eng. at that point-RK3368 CSA91/R8/R68 V2, V4
its in there
and
focus_kodi.png is netflix
Originally posted by krypton View Post
i know they have not even change the name of png for Netflex ... exploring the xml files now
Ok fixed it and hope it will work please test and confirm as i don't have the stock firmware installed.
Download: https://goo.gl/UUHFXi
thanks seems good
kodi link works fine
had to directy replace apk and set permissions due to different signing key ofc
did you zip align the apk?
also something which would be nice if your bored some time
if you replace youtube with the leanback 2.01.04 the youtube shortcut doesnt work with it
due to a slight difference in the naming
the leanback apk defaults to 4k btw..
but has the downside of not being able to use a mouse
app is signed and zipaligned-RK3368 CSA91/R8/R68 V2, V4
k2 doesnt work with the old 1.3.11 youtube apk or 2.01.04
2.01.04 is armv8 if that makes a diff
no i dont have another launcher
but its ok im just installing over the top of k1
as the signing is the same at worst i will have to factory it
k1 works fine with 1.3.11 btw its just nice to have the choice of 2.01.04
just noticed there's a new build 2.02.08 that works with a mouse or remote
think it has the same id as 2.01.04
not really sure why k1 works with 1.3.11 fine but not the newer versions
1.3.11 + 2.01.04 + 2.02.08 all id as com.google.android.youtube.tv
https://www.apkmirror.com/apk/google...-apk-download/Last edited by Shonk; 01 January 2018, 13:12.
Originally posted by Shonk View Postk2 doesnt work with the old 1.3.11 youtube apk or 2.01.04
Yep 2.02.08 which I'm also using "com.google.android.youtube.tv" it should work. What happens when you click or select ... because click and touch/select have different behavior in source.
also uninstall the appstore's youtube if installed and check the behavior. i'll make some more changes and see where the problem is.-RK3368 CSA91/R8/R68 V2, V4
if you update youtube.tv it doesnt work
mouse click on it or remote select click both do nothing with the newer builds
i can ofc use the stock icon in apps and it works fine
but the large youtube shortcut hard coded doesnt work
its always been that way 1.3.11 that the box comes with works fine with the stock launcher
ok try this one https://goo.gl/gcbyzE lets our finger crossed. otherwise we leave the youtube.tv alone i don't want to break the launcher fixing it-RK3368 CSA91/R8/R68 V2, V4
[QUOTE=Shonk;n698211]
/QUOTE]
ok try this one and let's keep our fingers crossed. Otherwise we leave the android.tv alone I don't want to break the launcher fixing it.
There are currently 2611 users online. 0 members and 2611 guests.
