LightHome Launcher With New Look and Optimized
Seems strange...
I got SQlite DatabaseBrowser portable and loaded the database.
It contains android_metadata, shortcut, sqlite_sequence n some more tables
After query SELECT * FROM shortcut I received the following:
id category componentName persistent
"83" "games" "ComponentInfo{com.android.music/com.android.music.MusicBrowserActivity}" "0"
"91" "favorates" "ComponentInfo{com.netxeon.kodiloader/com.netxeon.kodiloader.SplashActivity}" "0"
"92" "favorates" "" "0"
"93" "favorates" "" "0"
"94" "favorates" "" "0"
"95" "favorates" "" "0"
Thats what i have noticed too on Mac sqlite3 with command line. If you view db file in text editor you will see the shortcuts with binary garbage... Haven't tried HEX editor yet.
It seems that the file has been applied some kind of compression or encryption.Last edited by krypton; 15 January 2018, 21:14.-RK3368 CSA91/R8/R68 V2, V4
Latest Updated Firmware for CSA91 based on Zidoo Full/Lite (Working Hardware Clock) by krypton
Originally posted by soldiaz View PostMaybe you can participate in this one. I could not get it to work after changing Icons, edit assets and recompile...-RK3368 CSA91/R8/R68 V2, V4
here we go!
Edited zip: http://mystore.to/dl/7KJVrB0xDq
Original apk: https://apkpure.com/noblex-launcher/...ex.gm.launcher
I appreciate your help!
I can supply my build as well!
Here is the test-file download and install. Only first shortcut for IPTVextremePro is replaced. if you have provided the name correct "com.pecana.iptvextremepro" it should work.
https://mega.nz/#!MmZiAD4b!zc1_rec5U...JRxtE4d041l7bALast edited by krypton; 19 January 2018, 20:10.-RK3368 CSA91/R8/R68 V2, V4
Originally posted by soldiaz View PostAwesome man! Works!!! Thank you so much!
Apk can ne installed and iptvextreme Client launches!
How you Made that?
APK file should decompile and recompiled properly. Your extracted source was incomplete and the file you were editing was not the only one which needs to be modified
other source also need to be take care for proper compilation of apk file. I use Linux/Unix and OSX for reverse Engineering.
Originally posted by soldiaz View PostGuess would be better to link iptvextreme (freeversion). What you think?Last edited by krypton; 20 January 2018, 15:13.-RK3368 CSA91/R8/R68 V2, V4
Really awesome! Thank you so much!
I own modified icons as well.
Guess, there is a different name for the free version! What you think? Better integrate ad-served version?
How did you manage? Is it difficult?
Here are package names:
IPTV EXTREME com.pecana.iptvextreme
Settings com.android.settings
Filemanager com.droidlogic.FileBrowser
Firefox org.mozilla.firefox
Store com.android.vending
RetroArch com.libretro.retroarch
Superretro16 com.bubblezapgames.supergnes
IPTV EXTREME PRO com.pecana.iptvextremepro
Browser com.android.browser
There are currently 2028 users online. 1 members and 2027 guests.
