LightHome Launcher With New Look and Optimized
    [QUOTE=krypton;n698216]
    Originally posted by Shonk View Post
    its always been that way 1.3.11 that the box comes with works fine with the stock launcher
    if you update youtube.tv it doesnt work
    mouse click on it or remote select click both do nothing with the newer builds
    /QUOTE]
    ok try this one and let's keep our fingers crossed. Otherwise we leave the android.tv alone I don't want to break the launcher fixing it.
    https://goo.gl/gcbyzE
    nope
    this anything to do with it?
    AndroidManifest.xml 2.02.08 android:name="com.google.android.apps.youtube.tv.c obalt.application.TvApplication"
    AndroidManifest.xml 1.13.11 android:name="com.google.android.apps.youtube.tv.a pplication.TvApplication"
    see the extra .cobalt
      [QUOTE=Shonk;n698218]
      Originally posted by krypton View Post
      nope
      I'm not sure but app should call by its name... I have to check with command line from the terminal to open the app manually if it works. if it works then it should work with the launcher.
      -RK3368 CSA91/R8/R68 V2, V4
      Latest Updated Firmware for CSA91 based on Zidoo Full/Lite (Working Hardware Clock) by krypton
        [QUOTE=krypton;n698223]
        i have ssh on it give me the command to paste and i will try
          [QUOTE=Shonk;n698224]
          ok one more shot ......
            great work looks really nice thanks for sharing
              [QUOTE=krypton;n698232]
              https://goo.gl/cL6oP1
              sold
              works a treat
              thanks so much
              what was it btw
              if you are super super bored
              if you could hide the status bar on youtube 2.02.08
              that would be me sorted then
              https://developer.android.com/traini...ui/status.html
              sorry to be that guy
              but im a hack at best and can hardly stumble around an apk
              and its rare to find someone who knows how to do it
                [QUOTE=Shonk;n698257]
                That is a SYSTEM problem, not a app problem!
                  Shonk
                  I didn't test it fully, but latest App Settings (Xposed module) seems to be partialy (maybe fully) working. It has an option to force "Fullscreen" of an chosen app. Fullscreen means that StatusBar will be hidden (it doesn;t touch NavBar, but it is hiding by itself).
                  Maybe try it?
                  ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
                    [QUOTE=superceleron;n698430]
                    you can put a flag in the apk to force hide it see the link i posted
                    hence how kodi hides it and the stock launcher etc
                    • superceleron
                      superceleron commented
                      Editing a comment
                      you also need that in youtube app...
                    #40
                    Dear experts, really awesome! I do face issues on modifying NOBLEX LAUNCHER. I decompiled, exchanged some pictures and built up again. But package is corrupted..can someone help out?
                    Second, I ve been looking around for the NES TV LAUNCHER (pls see link for it) and another one which seems to be a modified NOBLEX LAUNCHER (see picture Click image for larger version
ID:	701661Click image for larger version
                    Any help appreciated,
                    kind regards soldiaz
                    Last edited by soldiaz; 14 January 2018, 19:55. Reason: had issues with link. could not remove. had to insert a link...i chose google
                      I do not know whose this file: Lighthome_K1_launcher.apk.
                      But it is awesome! Runs on XORO HST 260s! I wonder if it was possible to change KODI to IPTVextremePRO?
                      Can I just edit?
                        Yep. You have to decompile it, change files/code and than recompile it back. First part is easy, last may give You a problems if You make wrong changes in second, but second (without knowledge where is picture/lines You are looking for) is the hardest part of modding an apk.
                          I edited these strings:
                          <string name="package_xbmc">MY_DESIRED_PACKAGE</string>
                          <string name="package_kodi">MY_DESIRED_PACKAGE</string>
                          but APK Studio exits with -1...
                          Would be awesome to habe retroarch and iptvextreme default icons
                            Editing wrong file. Lighthome launcher shortcut data is stored in sqlite format 3 database unlike other TV launchers and which I guess is also encrypted. I'll try to decrypt it over the weekend and will see what we can do with it.
                              Thanks! I ve seen that sqlite database in assets, right?
                              I appreciate your help!
