TANIX TX3 Max & Mini - DUAL OS EDITION - LibreELEC + Android -> (S905W)
More problems every day and in every construction... that of the engineering guys is something that I do not believe anymore... I think you are only in this and that is bigger every day than yo... this support is very big for your possibilities... forgive me, but it is impossible to think otherwise.
Tamix you should rethink your customer service better post purchase or simply limit the updates until they work decently
This is not XDA, Samsung or anything less ... but nevertheless there should be much more serious and careful updates that are published every day
Originally posted by joseanvelasco View PostHello, anyone knows if you can put a usb wifi adapter ac which is compatible in libreelec,
thanks and regards.
If you are at all serious though spend a bit more and get a home plug and save yourself a lot of grief, or if you have an old wireless router you can convert it into a wireless adapter.
Wifi dongles don't have the power for serious streaming.
I installed the atvexperience but after that I had a problem with the bootloader, the tv box is no longer identified on the computer, even with the short on pins 7 and 8, I had to install the img 20180125 by the burn card maker, but it still does not identify on the computer by USB cable, what should I do? (the android is turning on and working normal, but in the future when I want to change the rom again I will need the bootloader to work)
Originally posted by NayamAmarshe
ATVXperience is based on tanix firmware so it's impossible to brick your device with it.
when using burn card maker you shoudn't select erase bootloader.
Also, this thread isn't the correct thread to talk about ATVXperience.
You just deleted the bootloader. Shouldn't have done that. Now you can use amlogic usb burning tool, search on google for its tutorial.
There are currently 1566 users online. 0 members and 1566 guests.
