Gesendet von meinem TX9 Pro mit Tapatalk
TANIX TX3 Max & Mini - DUAL OS EDITION - LibreELEC + Android -> (S905W)
Originally posted by tintenatze View PostXcuse me but where do ifind asingle Android Version for the tx3 max without a freezing Problem? Max not mini cause i need a working Bluetooth!
Quick instructions for changing libreelec build on Tanix TX3Mini (and other p281 devices, but to use other than tx3 original remote you need a fitting remote.conf):
Because libreelec was always freezing and android is not my #1 OS I looked for a way to change the libre-part into other build. For me this Version works way much better and pretty stable for several days now. Okay, somehow the script for the symbols on front display are missing(if sending the commands via ssh it could show the symbols..) and the box shows just the time, but that seems to be a good price for a fluid working libre.
At least the change is quite simple and done in under 10 minutes, few more if you do a twrp backup to be safe before.
Requirements: TX3mini with any Dualboot ROM installed and libre booted once, PC with adb and/or ssh OR as alternative µsd-card or pendrive.
The first two steps are always the same, for other steps use the method you prefer:
1. Download the zip with all files needed (source is kszaq's build for SYSTEM/kernel.img https://kszaq.libreelec.tv/s905/8.2/8.2.3.1/ plus the remote.conf & dtb.img from tanix build) found here: https://mega.nz/#!AHQHUSSA!UhY8Fkvm7...Xz6Zoc48-bnBPY
2. unzip it on PC (or to card/pendrive if you want to use this method)
I ADB-Way:
3. boot Box to android system
4. connect to device via adb, remount as root and copy all files:
Code:adb connect 192.168.1.55:5555 #alter fitting to your boxes IP but keep port :5555 adb root adb remount adb push remote.conf /data/.config/remote.conf adb push SYSTEM /system/SYSTEM adb push kernel.img /system/libre/kernel.img adb push dtb.img /system/libre/dtb.img
II SSH-Way:
3. boot to libre
4. connect via ssh, remount flash writable and copy via scp all files:
Code:ssh [email protected] #sure use your IP with the password "libreelec"
Code:mount -o remount,rw /flash #to make flash writable exit #to exit ssh
Code:scp remote.conf [email protected]:/storage/.config/remote.conf scp SYSTEM [email protected]:/flash/SYSTEM scp kernel.img [email protected]:/flash/libre/kernel.img scp dtb.img [email protected]:/flash/libre/dtb.img
III if going via pendrive/µsd card:
3. boot to android
4. open root file manager
copy the files to correct places(if problems occur, delete old files before):
place remote.conf in /data/.config/remote.conf
place SYSTEM in /system/SYSTEM
place kernel.img in /system/libre/kernel.img
place dtb.img in /system/libre/dtb.img
5. reboot to libre and be happy!
Also often people need widevine for several kodi add-ons - connect via ssh and enter:
Code:curl -Ls http://nmacleod.com/public/libreelec/getwidevine.sh | bash
Originally posted by tintenatze View PostWhow,tks for your amazing answer but I dont use Libreelec, my android freezes in all my three TX3 Max boxes.
mainly streaming! but also browsing, whatsapp, ip cam viewer, amazon prime video, working with textmaker. I´ve also a TX3 mini and also TX9 pro ( using the Alice UX launcher apk, which i found here.) I like to use similar working boxes for all rooms -3 TVS and two beamer( for one i use a bt speaker in the bathroom) and Alice UX is really lovely and easy to use. The bluetooth is in need for bt headphones and a bt keyboard for whatsapp.
Okay, even when most things could be done with libreelec and some addons(browsing=web viewer, ip-cam=surveillance room, amazon vod addon..) I understand that you like to use android and alice ui(I like the look too, but would prefer a green version instead of the red..), but it seems it is hard to find a stable rom with bluetooth.. Maybe it is easier for you to use a 3.5mm jack bt transmitter(around 8 euros€€) for sending sound to headphones and a usb mini wireless keyboard(got mine last year with german layout and backlight for under 10€ euros shipped..) for writing, together with a stable rom without proper bt support to get rid of the freezes?!
For single boot version (max/mini) with bluetooth (max):
Originally posted by JavimetalOk, I have a new Android Alone BETA for testing 20180125
Changes:
1. Update Airscreen, Netflix, Google Play to a new version
2. New funcion: WiFi Emulator (settings > more settings) for those apps do not accept LAN conection
3. Added TWRP at recovery screen
4. Removed battery icon from status bar
5. Fixed some video playback freezings
DOWNLOAD IMG: Beta 20180125 image
DOWNLOAD ZIP: Beta 20180125 update
this is the same description for the last TX9 pro update that i updated in january from tanix firmware download site!Last edited by tintenatze; 03 May 2018, 18:57.
Thank you Sergey11, the installion was successful in my TX3max, Alice, play store, LAN Emulator , Wifi, BT, Amazon prime Video are properly working. I will test it for some hours , i am begging that there won`t be and freezing bug anymore!Originally posted by Sergey11This topic for "dual boot system".
First testing day 8 hours without freezing! No problem with any of my apps. Kodi, ARD,ZDF, not laggy no blurring, no rainbow effects! My Gyromouse Minix Neo M1 every buttons are working. OEM remote all buttons woring except mouse button- no mouse cursor appears! Fake Wifi is perfect for using whatsapp on the box. ARD, ZDF live tv perfect! Kodi and Zatoo TV ok! I installed yor beta via upate & backup app from USB. No wipe data! No Apps lost, every acount: Google and amazon still working.. Thank you Sergey11 and .Javimetal for this beta. ill try some more time and if there is no freezing i will try to fix my other boxes with this beta.txs a lotLast edited by tintenatze; 06 May 2018, 08:22.
Originally posted by Masteralivex View PostHello! what is the best dual firmware to use libreelec?
My recommendation is to use the Dualboot build where your android works best and change the Libreelec-Part to the build of kszaq like described here in my post last week: http://freaktab.com/forum/tv-player-...460#post723460
Only "problem" after over one Week with that setup is that Frontdisplay only shows the Time, but no symbols for usb, lan, play, but Kodi works for me pretty flawless now-no freezing, no stuttering and all files from HDD, NAS or Streams are shown/played as wanted..
There are currently 2264 users online. 2 members and 2262 guests.
