TANIX TX3 Max & Mini - DUAL OS EDITION - LibreELEC + Android -> (S905W)
Thanks for the great work on this firmware!
Could anyone tell me where I can find the KERNEL source code for the 3.14.29 kernel in this LibreElec release?
I've flashed the recovery partition from the image in LE-p281-ota-20180125.zip and it boots fine on my box- TWRP is great but I need to compile a kernel module that changes the zimage.
I've extracted the .config and built it with the commit https://github.com/adamg88/linux-amlogic dated 05-sep-2017.
It compiles with gnu gcc and linaro 4.9-2014.09 but when I flash it to recovery, it does not boot.
I can repack the original recovery zImage & initrd from LE-p281-ota-20180125.zip so I'm sure mkbootimg is working ok.
Please help.
Originally posted by dbsharpe View PostThanks for the great work on this firmware!
Please help.
Originally posted by adriano.digiere View PostThe version 20180309 still freezing for me when using IPTV streaming. Until now, only version 20180125 works fine for me.Android TV Box direct from China. English & Español
Originally posted by polde66 View PostHi
I moved in. 20180309. The box temperature ranges from 75 ° C to almost 80 ° c. I think it's not ok for the box so I went back to v.20180125.Android TV Box direct from China. English & Español
Sergey11 claw3000
TANIX TX3 MAX & MINI - DUAL OS EDITION - BETA
v. 20180313
DOWNLOAD .ZIP FILE HERE
Change log:
- 32bit LibreElec
- Updated google GMS
- Fixed some video playback freezeing and drop frame issues
- Android graphic layer is now 1080p
- Fixed some ALICE UX bugs (next version of Alice is comming soon)
- Fixed (hope) the called "rainbow issue". Credits to Sergey11 and claw3000Android TV Box direct from China. English & Español
This method by claw3000 works conditionally and only when the AFR Level 2 is enabled: echo 1 > /sys/module/di/parameters/bypass_hd
Also, please draw attention to this problem:
1)Returning to the original screen resolution does not work on some iptv applications and Smart YouTube TV(attach the link). After switching the channel the AFR (Level 2) is activated (Video conversion 60 Hz to 25 Hz), but after the channel is turned off, the screen remains in the resolution to which it was switched by AFR (25 Hz). In this connection, the interface starts very slowly work, until the moment you manually switch to native resolution of TV in the settings.Last edited by bodrick; 14 March 2018, 17:16.
v. 20180313
Change log:
- 32bit LibreElec
The problem is not solved. If the settings put 1080/60 auto and afr off, then the rainbow is still there
There are currently 1929 users online. 0 members and 1929 guests.
