I got that also. I did my other boxes and the rest took 5 minutes or so total.
You have to open burning tool. Add image. Plug USB into computer only. Then press Start. Then plug USB cable and power cable into box at the same time. You will hear a whole bunch of noises like it's mounted and unmounted several times. The progress bar will start moving. It takes about 3 minutes per box on my computer. Once it reaches 100%, unplug the box from the computer, then hit Stop button in burning tool.
Sometimes you have to do the plugs USB and power cable at the same time step a couple of times. Just unplug, press Stop on the program, press Start and plug in again until it works.
