TANIX TX3 Max & Mini - DUAL OS EDITION - LibreELEC + Android -> (S905W)
Originally posted by Javimetal View Post
Updated to 1.1 (20180109)
Change log:
1. Fixed menu key (hamburger button). Working now.
2. Allow installation of addons from unkown sources.
3. The vfd can show wifi, eth, usb, play, pause.
4. LibreELEC Reboot Window. Now you can reboot to android from every skin. Just press "Power" button on your remote.
How to boot from LibreELEC or Android? When you are running one of the systems, just long press "power" button on your remote. A menu will be displayed, then, you can reboot to the other OS.
Sample when using Mimic
All subscribers have been notified by email. Remember check your spam folder.
If you are new to this firmware, download here
p.s. Sorry bad english
Originally posted by huaak View Post
I could set it to any language I want found in kodi settings / interface / regional / language press okay-button and you'll get a list to choose your favorite language
I really like this firmware! It came exactly in time before facing the toothpick procedure for dual boot with SD, and I have not enough SD cards fo my protoboards!
I'd like to know if it's possible to configure an external IR remote with the IR receiver onboard. With my Odroid C1 and with my Rasperry PI 2 (+ PiFi board) I'm using a PlayStation2 IR remote configured with lircd. If it's possible, I'd like to use it on LibreElec and Android too.
Is it possible?
Moreover i'm having a problem on Android. I can't find TV Center and the Kodi Upgrade tool can't install it properly. Neither the downloaded APKs can install. They give error -505 at the end of installation.
Any hints?
Originally posted by varma View PostI can't find TV Center and the Kodi Upgrade tool can't install it properly. Neither the downloaded APKs can install. They give error -505 at the end of installation.
Any hints?
Originally posted by hojnikb View PostAny word on libreelec only version ? This dual os is great, but it's not possible to boot from sd card.
add the correct dtb.imb
start android
intall Shell Terminal Emulator on playstore
launch it
put your micro sd on slot
type on Shell Terminal Emulator the command :
reboot update
Originally posted by manu_manu4 View Post
Burn your openelec img on your micro sd
start android
launch it
reboot update
If I am right, if you install the Dual Boot firmware and you want to boot LibreELEC from a TF Card, all what you have to do is pressing several times the "Menu" button just after connect your box. Then it will boot from the TF.
Just need to do it the first time, after that, every time will boot from TF card (if present with the correct files).
I have to try it myself........Android TV Box direct from China. English & Español
hi,
i installed the new Firmware 1.1 yesterday. After an half Hour the Box Freezes under Android whlie using DAZN App. Only Power off and on helps.
The LibreELEC Boot is very good.
How can i put my Kodi Data in it?
I thought when i´m running Libre all my Data will be available trough Kodi from the Androidversion.
But it´s a clean Kodi.
Do not believe me 100% right now because I did not pay too much attention when they explained but:
I guess this could be fixed by setting the bootloader to boot from sd card first, then libre or android second, whatever you set before. Without the sd card present, it would boot straight to nand by default. Or maybe give us a 3rd option to boot from sd card when needed.
There are currently 1911 users online. 0 members and 1911 guests.
