TANIX TX3 Max & Mini - DUAL OS EDITION - LibreELEC + Android -> (S905W)
..after testing the android-part yesterday a bit more, I didn't discover any problems so far.
First I watched one hour stream in browser, after that I turned music on in kodi for an hour and watched a movie afterwards. Over night I let the box play several videos(screen and amp turned off), but tx3 was still playing flawless when I turned on monitor the morning again. Maybe those issues with the freezes are related to the power supply like the half-reboots I had some weeks ago, which never appeared again after changing the power supply with another tv box having the same specs(5V/2A)?!
Originally posted by hojnikb View Post
You could install chrome browser to libreelec/kodi and use from there.
Updated to 1.1 (20180109)
Change log:
1. Fixed menu key (hamburger button). Working now.
2. Allow installation of addons from unkown sources.
3. The vfd can show wifi, eth, usb, play, pause.
4. LibreELEC Reboot Window. Now you can reboot to android from every skin. Just press "Power" button on your remote.
How to boot from LibreELEC or Android? When you are running one of the systems, just long press "power" button on your remote. A menu will be displayed, then, you can reboot to the other OS.
Sample when using Mimic
All subscribers have been notified by email. Remember check your spam folder.
If you are new to this firmware, download here
Last edited by Javimetal; 11 January 2018, 15:31.Android TV Box direct from China. English & Español
And another things. Today I installed new dual boot release and while I was watching YouTube at 720p tx3 hangs up with no possibility to stop resume etc.,completely stopped, I had to remove power for rebooting, note that my tx3 is new, just arrived 6 days ago and Install original kodi after removing tvcenter before upgrading.nothing else and kodi library completely free And I have not run librelec yet, the only things is that I was moving some files with file manager from USB drive to internal memory while watching you tube. Can be this the problem, I pretend too for this electronic? Thanks to all
Inviato dal mio Moto G (5) Plus utilizzando Tapatalk
Hello everybody! Downloaded and installed a new firmware TANIX TX3 MAX & MINI "DUAL OS EDITION"
UPDATE TO v1.1 (20180109) on the Tanix TX3 Mini. Unfortunately TV box still hangs when watching IPTV and when watching movies. Used MX and VLC players, stopped several times, helped only power down.
Originally posted by doomer View PostHello everybody! Downloaded and installed a new firmware TANIX TX3 MAX & MINI "DUAL OS EDITION"
There are currently 1791 users online. 2 members and 1789 guests.
