TANIX TX3 Max & Mini - DUAL OS EDITION - LibreELEC + Android -> (S905W)
Originally posted by zepperdude View PostOnce in Libreelec - how to I get back to Android? I shut down or reboot and it goes back to Libreelec.
but that only works in default skin
I just discovered this with mimic, even if i added an option for activatewindow(shutdownmenu) it was not the modded menu with reboot to android on it
which brings me to the question i just came here to ask
QUESTION: what is the command for "reboot to android" so those using custom kodi skins can add that option to their menus...
Thanks for all this feedback. Tomorrow I will collect all and make a report.Android TV Box direct from China. English & Español
Perhaps somebody can make a little youtube-clip how the dual boot is working?
Javimetal
when i have the dual boot installed, the android part of the rom is the same rom as i have it now installed ? (last ota update zip-rom from 20.12.2017)
all my installed apps and settings i will keep ?
as i understood, LibreEELEC is good to use for Kodi, but using the other apps as youtube, browser, terrarium, stremio etc i can boot and work with android, because there is no advantage using LibreELEC. And i boot in LibreELEC when i use Kodi.
Is this correct?
Think of LibreElec as a faster os less bloat ect good for devices with less memory ect kodi runs faster in it. But that's the plus side. Down side is you get just kodi so kinda limited so depends on what you want To do with
device.
You'll lose settings apk you have yes.
But can boot into either your choice.
Originally posted by tombraga View PostPerhaps somebody can make a little youtube-clip how the dual boot is working?
Javimetal
Is this correct?
So is it not like a similar update i did before with the rom-updates from Tanix rom 15.12. to 20.12 rom? (see picture)
when i did this update last time with ota update, all me apps and settings still continued as before.
and concerning your comment, that LibreElec has bless bloat and good for devices with less memory, is this also correct for this dual boot rom, where i have two operation systems installed, so more then only LibreElec?You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by dimspace View Post
if you are in the default skin, click on teh power icon and it will offer, power off - custom shutdown timer - reboot - reboot to android
2. /usr/sbin/rebootfromnandAndroid TV Box direct from China. English & Español
Originally posted by laniks View PostSamba does not work in libreelec. Does not see the server windows. But on the android in kodi
everything works correctlyAndroid TV Box direct from China. English & Español
There are currently 3548 users online. 0 members and 3548 guests.
