Enviado desde mi Aquaris V mediante Tapatalk
TANIX TX3 Max & Mini - DUAL OS EDITION - LibreELEC + Android -> (S905W)
Originally posted by huaakWell the best Dualversion should be that one from end January( http://freaktab.com/forum/tv-player-...664#post704664 ), but there are also few problems(occasional freezing and weird movements in Video in some Formats).
My recommendation is to use the Dualboot build where your android works best and change the Libreelec-Part to the build of kszaq like described here in my post last week: http://freaktab.com/forum/tv-player-...460#post723460
Only "problem" after over one Week with that setup is that Frontdisplay only shows the Time, but no symbols for usb, lan, play, but Kodi works for me pretty flawless now-no freezing, no stuttering and all files from HDD, NAS or Streams are shown/played as wanted..
Look in another thread here about installing kodi on sd card for 905w chip. Take a look here
Originally posted by Masteralivex View Postthank you very much, I will try although it seems complicated for me
I also ran kaszaq's librebuild from usb and sd card, but with a large collection of media on external hdd it had several performance issues when loading all the vast of thumbnails and Descriptions, because even on a pretty fast sandisk extreme pro µsd-card it took much time to load all informations. Once loaded it was okay using it, but I prefer the Libre on nand as it works much faster..but no matter if from internal or from µsd the best Librebuild is that from kszaq!..Last edited by huaak; 07 May 2018, 14:01.
Originally posted by huaak View Post
..no, it isn't complicated...maybe it seems so because I mention three different ways how to change the three or four files you need, but basically it is really just copying/replacing some files. Choose just one of the ways, fitting best to you!
Originally posted by paulopais View PostWith kszaq version or display works ? You have Netflix ? Yes .. nand is pretty fast.Code:echo wifi > /sys/class/leds/fd628_dev/led_on
No, I personally use no paid services at all on tx3 or any other box, so no netflix, amazon, zattoo-Premium or elsewhat here. The few live-tv-channels I need occasionally I get via zattoo basic and/or 7live-tv addons in Kodi. Most files I play are on 1tb external hdd(formatted ext4, but ext2 without journaling would be even some milliseconds faster), from 4tb in nas or Radiostreams via radio or somafm addons.. and because nand is so fast compared to pendrives or cards I prefer libre there with the mass of files to load-and the change in a existing dual boot rom is pretty easy and done in under 10 minutes..
Originally posted by huaakOn LED-Front-Display is shown just time, but the symbols work basically(if you send the code-for example the command to show wifi symbolCode:echo wifi > /sys/class/leds/fd628_dev/led_on
Sent from my SM-G955F using Tapatalk
Originally posted by huaakOkay maybe the symbols were activated in the Kodi 18 builds, but because I had issues with the 18 alphas some months ago, I use(d) kszaqs krypton builds. Maybe I should give Leia a try again?!..which branch did you use, or did you switch to coreelec??
Originally posted by paulopais View Postbut it's great coreelec
I will try coreelec on my test-device the next days, because Coreelec and kodi leia need a fresh & empty configuration and I don't want do drop just for testing my pretty large database with all movies, episodes and music from hdd and nas working perfect on libreelec with kodi krypton..
Thank you, but the downloads I could do myself, the only thing what would be interesting for me is the content of the vdf-file working for you..
..oh, I thought there are several possibilities to setup the display with the vdf.conf(here a part of mine):
Code:#chars: # < DHHMM > Order of display chars (D=dots, represented by a single char) vfd_chars='0,1,2,3,4' #dot_bits: # Order of dot bits. Typical configurations: # Display Type 0, 1 usually has Alarm, USB, Play, Pause, Col, Ethernet, Wifi dots # Alarm = 0, USB = 1, Play = 2, Pause = 3, Col = 4, Eth = 5, Wifi = 6 # Display Type 2 usually has APPS, USB, SETUP, CARD, Col, HDMI, CVBS dots # APPS = 0, USB = 1, SETUP = 2, CARD = 3, Col = 4, HDMI = 5, CVBS = 6 # Display Type 3 Power, LAN, Col, Low Wifi, High Wifi # N/A = 0, N/A = 1, Power = 2, LAN = 3, Col = 4, Low Wifi = 5, High Wifi = 6 vfd_dot_bits='0,1,2,3,4,5,6'
Well, as I know the fd826 addon is only available (and working?!) in Kodi 18/Leia builds, but not in Jarvis or Krypton..from which repo did you install it? You got a link or a zip of the fd826addon?!
There are currently 2277 users online. 0 members and 2277 guests.
