[ROM] Tanix TX9 Pro / Vorke Z6 Plus - based on Magendanz´s Vorke Z6 / Tanix TX92 Stock & Nano Nexus ROMs (Android 7.1)
Originally posted by Alianato View Post
you must install zip via twrp, I believe I installed SuperSU v2.82 http://www.supersu.com/download
perhaps installing the zip via the "about" in "settings" may also work, from what I recall the result is a boot into recovery
Originally posted by Alianato View Postbuild from Vorke Z6 Plus stock and based on Magendanz ATV stock version
https://uptobox.com/z83pl10xye4o
Muchas gracias por tu esfuerzo y trabajo.
You could upload this version again and if possible for OTA.
Thank you very much for your effort and work AlianatoLast edited by kain75; 04 June 2018, 21:16.
Originally posted by alesul View PostAfter 1 week of use Magendanz rom in Vorke z6 plus a lot of crush begins and also freezing screens....I can use the device just after I take the AC plug from device! I believe something is not ok.....Other people have the same simptoms?
I have the same problem with the version of Stock when using it after connecting to the anergy, but if I let it happen for a while, is it a hardware or software error?
I tried installing this with usb boot card maker with usb drive. it only boots into recovery. tried install from udisk, but couldn`t find it.
I`ve also installed windows 10 on my MacBook pro and used a usb/c to usb cable to use burning tool, but device wont show. What can I do... please help
Originally posted by Alianato View Postlatest Magendanz non ATV roms based on:
Vorke Z6 Plus (nano)
Vorke Z6 Plus (stock)
Tanix TX9 Pro (nano)
Tanix TX9 Pro (stock)
ATV versions will follow soon
I'm using latest firmware 6/6/2018, the videos still freeze occasionally. Accept from that i felt the 5Ghz wireless is bit slow, or it's signal is not strong compare to my Telos S95. I still need to use LAN to watch really big size movies. If they could fix the freeze, this box would be almost perfect to me. Most i read they mentioned about heated hardware. I don't know
Anyways, i decided to test this ROM last night. Though i lost some of the cool features, like the front screen panel. It's finally work again. I can watch my movie without freezing. So happy right now, i really thought it would go wasted this box.
Will update if i know more. Still not getting use to ATV, currently learning.
Much thanks to creator and TS.
Originally posted by Alianato View Postlatest Magendanz ATV roms based on:
Tanix TX9 Pro
Vorke Z6 Plus
Is there any chance you can create updated versions of these that use the latest Tanix TX9 firmware (2018-02-05) or explain how I can update the existing one to latest firmware.
Originally posted by kozekz View PostI'm using latest firmware 6/6/2018, the videos still freeze occasionally. Accept from that i felt the 5Ghz wireless is bit slow, or it's signal is not strong compare to my Telos S95. I still need to use LAN to watch really big size movies. If they could fix the freeze, this box would be almost perfect to me. Most i read they mentioned about heated hardware. I don't know
Which ROM exactly did you use, and after 2 months are you still happy with the result?
Any update on your experience will be much appreciated
There are currently 2802 users online. 0 members and 2802 guests.
