Temp max 47°
[ROM] Tanix TX9 Pro / Vorke Z6 Plus - based on Magendanz´s Vorke Z6 / Tanix TX92 Stock & Nano Nexus ROMs (Android 7.1)
Originally posted by alesul View PostFor the moment is the best and stable rom with working lcd for our Vorke Z6 plus Magendanz ATV roms based on
Vorke Z6 Plus
Thanks Magendanz and Alienato.
But I hope Magendanz will make directly rom for our Z6 plus rom based on 20180126
Originally posted by Alianato View PostI am using the following as a solution for the excessive heat generated by this box
I just took out the box bottom and let it rest on top of this USB fan cooler, it works pretty well and have the advantage I don't need to cut the box caseexcellent work, thanks also for the continuous development of these ROMs
Originally posted by alesul View PostAfter 1 week of use Magendanz rom in Vorke z6 plus a lot of crush begins and also freezing screens....I can use the device just after I take the AC plug from device! I believe something is not ok.....Other people have the same simptoms?
post # 72 link
http://freaktab.com/forum/tv-player-...ck-nano-nexus- rom-android-7-1 / Page5.
But LCD not work fine.
Bye
I have two that bricked i think. I can't access recovery on either both have no Boot logo on the front and both don't display nothing. The first one when i try and flash with burning tool it fails around 2% with a 0x10105002 error. Second one with same Usb same and same firmware Feb2018 it flashes fine but says boot with no image now, but when i plug in a hdmi cord and it doesn't show boot?
Originally posted by Luca View Post
HI, with the latest official rom I have 2/3 freeze screen weekly. The only rom with no blocks I tested is Alianato on Guest base no ATV ROM:
post # 72 link
Bye
Nano
Stock
I expect this to be my last update for this box, good luck
cheers
new links for that version, 2017-11-19 (non ATV) and based on Vorke Z6 Plus
Nano
Stock
cheers
Last thing, the LCD patch on this version does not work, do you think you can adapt it?
did you try the following, I am not sure it will work
I taped by box internally with a black tape and forgot about the led, to be honest I prefer with the led off
I found that apparently this is the most stable rom for my Tanix TX9 Pro, you tell me ... (I am using the nano version)
Bye
it is the first version yes
Kodi 17.6 seems to work well, kodi 18 has some problems. youtube ok chrome and others app ok
Question, how can I root the box? I tried some tools without success.
Cheers
On the Russian forum, someone says that the voltage written on the motherboard is not the same as the measured.
I have done some checks and this is true, but those detected are correct according to the specifications of the components.
LPDDR3 1.2 Volt (no 1.5 as written)
CPU min 0,80v max 1,1v, it depends on the clock (1,1 as written)
EMMC 1.8v
The values remain stable in the box.
I really do not know what to think.
possible that 90% firmware not good?
I confirm that this rom has no blocks that requires on-off box.
Cheers
perhaps installing the zip via the "about" in "settings" may also work, from what I recall the result is a boot into recovery
There are currently 2344 users online. 2 members and 2342 guests.
