[ROM] Tanix TX9 Pro / Vorke Z6 Plus - based on Magendanz´s Vorke Z6 / Tanix TX92 Stock & Nano Nexus ROMs (Android 7.1)
Hello Alianato, it is possible that you make an Android TV version for the stock ROM of the Z69 plus TV Box?
I could flash the tranix tx9 ROM in this TV Box and works Ok, but I loose the remote control functionality.
I really apreciate if you coud help me.
Here is the link for the stock rom:
PS: Sorry for my bad english, but i'm using Google Translate for write in this post.
Originally posted by Alianato View Postnew version of the tool to convert to non ATV (install via TWRP)
https://mega.nz/#!1dJUBZ5T!68ObvcsHm...TKo9KZsKiJyFFE
most probably it will not solve the LED screen issue
I want to try this
Originally posted by Luca View Post
Hi, this link is no longer valid.
I want to try this
@tillaz87 . thanks anyway
Originally posted by DiegoDNL View PostHello Alianato, it is possible that you make an Android TV version for the stock ROM of the Z69 plus TV Box?
If you are Italian you can try the translator to Portuguese or Spanish, normally it works quite well.
You can substitute the original remote configuration by the original without having to rewrite the rom, in the next couple of days I am going to be a bit busy so I don't know if I will find the time to explain to you, be patient please
I can upload later to anyone that wants them
hi guys, I've tested this ROM, the first impression is that it's perfect for me.
No hangs, restart, freeze.
LCD work fine
Videos smooth.
Try it
Thanks again
New firmware
Changelog
– Updated Airscreen
– Updated Netflix
– Updated Google Play Store
– Added fake WiFi function (if we are connected by LAN, our device will think we are using WiFi). This is useful for some games as Asphalt.
– Removed status bar battery icon
– Fixed some video playback freezing
here we go again ...
at the moment I am building a new PC for me so I haven't much time to experiment
https://www.chinagadgetsreviews.com/...us-tv-box.html
https://openload.co/f/t1mkD1b61sA/Z6...0824_remote.7z
you should replace the remote.conf of your box with this one and see how it goes (it's available in /system/etc)
Originally posted by Alianato View Postbuild from Vorke Z6 Plus stock and based on Magendanz ATV stock version
https://uptobox.com/z83pl10xye4o
thanks in advice
There are currently 1667 users online. 2 members and 1665 guests.
